Hey Guys,
I have been a member of SAU for quite a while and had many imports. All on the S chassis and one Cima. Now I have just purchased this which so far has been by far the best buy.
It cost me $3000 and i organised a legitamate road worthy which it passed first time with no defects. So all up and into my name it has cost me approx $3300.
I bought the car and it had:
Advantek 18" rims
brand new yokohama tyres all round
HKS 3" exhaust
Drift Pod filter.
within about a week i have already purchase a set of JIC coilovers, and removed the HKS exhaust and made my own new rear section as the HKS one was very quiet and I really wanted to bring out that RB note, Also the HKS rear box was very heavy and as i want this to be a track car predominantly this was the main reason.
So here a picture of the exhaust i made. Which was actually made out of 3 S15 3" front pipes which i cut, welded, cleaned and painted.
I've also removed the HICAS which I will post up photo's later.
So far this is all i have done but this weekend i will be removing the front end and removing all the A/C and I will also start to remove all sound dedening etc.
The main focus of this car will be drift and track days.
I will soon be installing a Diff which is a little bit different to most. As i work for ARB i will be installing an Air-locker in the rear. as this will be excellent for drift whilst also making it daily driveable. I also have them in my landcruiser and love them.
I will keep you all upto date with the progress.
Cheers ben
https://www.sau.com.au/forums/topic/329079-r32-gts-t/
  • 3 weeks later...
so the major work is starting this weekend as I popped the headgasket which was kinda my own fault, so now im gonna treat the old girl to some lovin.
plans as off this week.
rebuild the RB20
metal headgasket
ACL race bearings
ARP head studs
custom intercooler
alloy rad
remove wiring and completely re-wire the car
complete removal of the air con.
strip interior
full cage
tub the front end
removale rad support.
rebuild brakes
diff
i will begin posting the progress this weekend.
Cheers Ben
https://www.sau.com.au/forums/topic/329079-r32-gts-t/#findComment-5385983
Interesting choice.
Do Airlockers need some sort of air compresser to run?
If not, how are you going to feed the air into locker?
Any benefits over LSD besides that you could get them at staff prices?
https://www.sau.com.au/forums/topic/329079-r32-gts-t/#findComment-5387886
well today it all began, the motor has come out and the engine bay stripped. Ill get some pics once my camera is up and running.
Ive marked all the wiring that is going to be stripped out. im looking forward to getting stuck into it during the week.
As for the airlocker mate, the main disadvantage to the airlocker is that you do need to remove the LSD and install the airlocker as its a complete centre and will then make it a single spinner when not engaged. The Air-locker does need a compressor to activate it, The compressor i am going to put in there weighs just on 1kg and is a 62ltr per min compressor. Which means it can also do tyre inflation when at a track to play with pressures. As this car is going to get driven also on the street the last thing i wanted was a 2 way as i wanted it to drive nicely and not so agressive when around town.
Heres a link to website for more info if your interested.
http://www.arb.com.au/products/arb-air-lockers-accessories/
The rear diff in a skyline is the same as a front diff in a D22 Navara V6 current model
https://www.sau.com.au/forums/topic/329079-r32-gts-t/#findComment-5388119
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
