Yeah you can. I had a heap of these made a while back. They are very expensive to have made but for the cost of a new N1 pump, you get unbreakable gears.
It's not something that's i'd do all over again but I put one in every new engine I build. Finding wire cutters and gear profilers is frickin time consuming!!!
^ correction - Most gears that is due to rev limiter abuse by the owner, which is a sure fire way to kill gears and ANY pump can be broken like that - even the Tomei.
Doesnt matter what crank you have in that scenario :P
Doesnt matter what crank you have in that scenario :D
I have to agree with R31Nismoid... But any limiter abuse can lead to that and many more problemes on any car. That can be taken out of the equation with some reasonable driving/shifting. From my experience and knowledge a nice N1 is good enough ! Just make sure you address the crank collar probleme if its a early model engine. As for billet gears , I know Nitto makes a oil pump for the RB but I have no idea on the performance/quality of this product.
http://www.nitto.com.au/products/oilpump-R...?vehicle=nissan
just my 2 cents :P
Doesnt matter what crank you have in that scenario :(
I really think it is down to the poor tolerance between the drive and the gears, then when you start applying on/off torque such as bouncing the limiter or heaps of pedalling, they break.
Good tolerance, good balancing and a decent harmonic balancer. (And some gears that aren't made of a sintered material).
Edited by bubba
Doesnt matter what crank you have in that scenario :)
I thought so too until I supplied 2 (two) N1 pumps to customers (from Nissan), both cars fitted with crank collars and both cracked the gear. One in less than 5000 kms, and the other in about 12,000kms.
Neither car saw over 7000rpm and had aftermarket harmonic balancers. That was good enough for me to lose faith in them completely
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
