Euro Style Interior Downlighting
domino_z
 Share
Hi guys
Just had my 2000km service and took a 370 for the day
Very impressed with the interior lighting at night, and appears it has the euro style interior led downlighting onto the centre console
The map light/interior light switch in the 370 looks to be identical to the GTR, even down to the tiny oval hole where the led emits the light
But on my GTR it doesnt illuminate. Now is it just my car, or is the GTR supposed to have the red downlighting as well? It seems strange theyd put an led in the 370 but not the GTR
If this is so, i might look into buying the map light piece out of the 370 and doing some retro wire taping
Edited by domino_z
I have a similar yellow LED in the 06 accord I had, actually is quite useful and not annoying. Shouldn't be that hard to retrofit it'd just be the issue of getting constant power there.
my m3 has the soft red downlighting as well, and illuminating onto white leather it looks great at night
would look really good in the GTR with red light illuminating the flat silver console
just strange that nissan put the same map light centre piece in the 370 as the GTR but pull the led out :P
ill go past jaycar and buy a few different angle 3mm red leds and see what works, otherwise i might see if buying the 370 map light isnt too expensive at the dealer
oh, and another thing i need to do is footwell lighting, yet another euro feature ive taken for granted
edit - this is where the led emits light from on the 370. You'll notice its identical to the GTR's - id imagine they'd use a 360degree led
check out this thread where they open it up, this is going to be easy
http://www.the370z.com/diy-section-do-your...html#post519440
Edited by domino_z
Im a huge fan of interior lighting when its done correct, i was in a Current S class the other night and it is stunning, 3 different color choices really classy in my honest opinion
i couldnt find any photos of the Zed but here is the S class in the "warm" mode
agree, the s-class (and the new e-class) under dash lighting looks amazing at night
the euro's have definitely moved on from putting leds under rear view mirrors and inside door handles
even our exterior needs attention, i put leds in the numberplate and parkers, and fixed the rear tail lights to illuminate all 4 stove burners
just strange that nissan put the same map light centre piece in the 370 as the GTR but pull the led out :)
And I always thought thats where the bluetooth microphone was! :)
Edited by fungoolie
And I always thought thats where the bluetooth microphone was! :D
the bluetooth mic is behind the vent/slats to the right of the OFF switch position
pulled the map light piece out today, its identical to the 370, even has the groves to slot the oem 370 led module into it
i shown a small led torch through the hole and think i know why they didnt put a led in
the light is dispersed back near the handbrake lever rather than over the gear trim surround. However this can be fixed by using a 180 degree led and playing around with the positioning to push the light forward, not too hard
ill get started next weekend, too bust trying out a new wax today
Edited by domino_z
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
