Euro Style Interior Downlighting
domino_z
 Share
Hi guys
Just had my 2000km service and took a 370 for the day
Very impressed with the interior lighting at night, and appears it has the euro style interior led downlighting onto the centre console
The map light/interior light switch in the 370 looks to be identical to the GTR, even down to the tiny oval hole where the led emits the light
But on my GTR it doesnt illuminate. Now is it just my car, or is the GTR supposed to have the red downlighting as well? It seems strange theyd put an led in the 370 but not the GTR
If this is so, i might look into buying the map light piece out of the 370 and doing some retro wire taping
Edited by domino_z
I have a similar yellow LED in the 06 accord I had, actually is quite useful and not annoying. Shouldn't be that hard to retrofit it'd just be the issue of getting constant power there.
my m3 has the soft red downlighting as well, and illuminating onto white leather it looks great at night
would look really good in the GTR with red light illuminating the flat silver console
just strange that nissan put the same map light centre piece in the 370 as the GTR but pull the led out :P
ill go past jaycar and buy a few different angle 3mm red leds and see what works, otherwise i might see if buying the 370 map light isnt too expensive at the dealer
oh, and another thing i need to do is footwell lighting, yet another euro feature ive taken for granted
edit - this is where the led emits light from on the 370. You'll notice its identical to the GTR's - id imagine they'd use a 360degree led
check out this thread where they open it up, this is going to be easy
http://www.the370z.com/diy-section-do-your...html#post519440
Edited by domino_z
Im a huge fan of interior lighting when its done correct, i was in a Current S class the other night and it is stunning, 3 different color choices really classy in my honest opinion
i couldnt find any photos of the Zed but here is the S class in the "warm" mode
agree, the s-class (and the new e-class) under dash lighting looks amazing at night
the euro's have definitely moved on from putting leds under rear view mirrors and inside door handles
even our exterior needs attention, i put leds in the numberplate and parkers, and fixed the rear tail lights to illuminate all 4 stove burners
just strange that nissan put the same map light centre piece in the 370 as the GTR but pull the led out :)
And I always thought thats where the bluetooth microphone was! :)
Edited by fungoolie
And I always thought thats where the bluetooth microphone was! :D
the bluetooth mic is behind the vent/slats to the right of the OFF switch position
pulled the map light piece out today, its identical to the 370, even has the groves to slot the oem 370 led module into it
i shown a small led torch through the hole and think i know why they didnt put a led in
the light is dispersed back near the handbrake lever rather than over the gear trim surround. However this can be fixed by using a 180 degree led and playing around with the positioning to push the light forward, not too hard
ill get started next weekend, too bust trying out a new wax today
Edited by domino_z
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
