is the standard rb25 flywheel in my 33 gunna be fine to balance up on my rb30 crank and use in my 2530? im assuming that there wasnt any huge weight difference between rb25det flywheel and rb30e flywheel? i have the box out of my 33 already so access to flywheel is easy and my crank is sitting at my engine builders waiting for a flywheel so we can balance it.  thanks james
https://www.sau.com.au/forums/topic/329134-flywheel-question/
all rb engines use the same flywheel so yes but id recommend a chromoly flywheel for peace of mind, herd some bad stories with high hp cars and stock flywheels
Like what? Flywheels disintegrating at high revs???
down here in hobart recently a flywheel came off an old holden and injured someone pretty badly but old holden engines had a habbit of loosing flywheels once high horse p.ower was run through them. Rb engines however are not built anything like an old 308. I do have a lot of trust in a standard flywheel for upto 400hp. And as its an rb30 bottom end being built it wont be revving as high as i had to rev the 25 bottom end.
Excellent, if all flywheels are the same i will pull the flywheel off the back of the 25 tonight.
Secondly, snozzle, do u run a chromoly flywheel? If so, what brand and what are they worth?
the can develop cracks after alot of abuse and eventually shatter - im running a twin plate that comes with a chromoly flywheel
nismo/exedy etc etc do lightweight chromoly flywheels
if you baby your car dont worry about it but if your gonna give it some abuse (majority of people on this forum) you should opt for a chromoly flywheel, not worth taking the risk, in my opinion
hahah i read this a day too late. standard flywheel already been balanced up with my crank and balancer. and yes car will be getting the ring smashed out of it. TRACK ONLY :) (plus.... secret, confidenial, shhh shhh, night time, back road, test work
:D )
oh and im guessing the heat scortch marks on my standard flywheel are normal??? i hope so....! If i hear any more 'shattered flywheel' stories im going to sh*t myself and build a scatter plate in my gearbox tunnel lol
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
