I had a look and there is a sticky where you can report your engine failures in another thread, and you can put up what you broke, what turbo you were running when you broke it, what oil you were using etc.
I’m interested if people could post up their transmission breakages and what power they were running, and what they were doing when they broke it (8k launches etc).
As i have a 21 year old GTR, I’m not sure how much the transmissions can take i.e. 4k launches etc.
Before i get flamed for not searching, i have searched and haven’t really found what I’m looking for
Cheers
Type of Car:
Modifications:
Power:
What you broke:
How you broke it:
Type of Car: 33 GTR V-spec
Modifications: dash 5's poncams, 600's, vipec, pump, 4" zorst and hks front pipe, straight cut 1-4 SYNCHRO box, Jim berry monty clutch
Power:441awhp
What you broke:3, 4 gears
How you broke it:if i knew, i wouldnt have done it >.< just casual driving and on the shift from 2-3 i magically smashed 3, which in turn made forced man love to 4 Via gear tooth rape and the rest is history. now i have a SC box, i expect to start breaking driveshafts :woot:
this was in january before the car came off the road and started being built into a serious race car.
car: 33gtst
mods: 3inch open pipe from turbo. 14 psi. Piggyback ecu. Fmic. Fuel pump. Short shift. Lock diff. Lightweight race rims. Suspension. Removal 150kg worth of factory crap and interiors etc
Power: 220 kw
what you broke: 3rd and 4th plus diff failure
how you did it: at symons plains raceway. Short shift made mince meat of 3rd and 4th syncros so smashing it into those gears resuslted in them soon failing lol. And it wouldnt be a good day out if a crown wheel bolt didnt mysteriously come loose and exit the half inch cast steel housing like a bullet leaving a hole half the size of a closed fist in the housing and demolishing everything it came into contact with inside the closed unit.
car: 33gtst
Power: 220 kw
car: R32 sedan
mods: standard rb20det, td06-20g, 6boost, tial gate, 3inch custom exhaust stinger, 21psi
power: 310hp
what you broke: 8puck cushioned exedy clutch went bang along with the standard 20det box.
how i broke it: a mate said i couldnt go better at the track than his 32 with a 25 in it. i did and had to limp home
Type of Car: 32 gtr
Modifications: nothing worth mentioning (n1 spec)
Power: ~250kw
What you broke: chain in the transfer case
How you broke it: well...never got it checked properly. it had just been rebuilt so i guess a mistake was made. Interestingly it ended up stuck in 3rd because the chain whipping around in the xfer cas bent the support around the shifter linkage and would not allow me to change gears. I thought it was a busted garbox for that reason
bet no-one else has managed that lol
 Share
