wrecking s1.5 and s2 r33 skylines heaps of parts have complete motor 5speed gearbox and loom ecu good condition 2900 ono,s1 motor unknown condition 600$,seats,boot with mspec wing,sideskirts,deep dished wheels 17-9 1390$ manual conversion 1400$,heaps of other parts,s2 airbag kit,have near complete 33 needs dash put back in and interior and dash loom i have all these parts want 4100$ for complete car.i dont come on here much so best to call or txt 0414333538 located at tweed heads
passenger front headlights, driver side stone guard?
Got any of the above parts im after?
got light but it is onm the near complete car so dont really wanto pull it off just yet
Hello, got a standard r33 gtst airbox?
Thanks
I need a rb25 clutch master from a r33 and need it now. I will take 2 if you have them both. Anyways please get back to me asap with pricing and i will pay immediately.
this is the one that bolts off the fire wall not the one off the gear box. I have had many people mix this up within the past couple of days, just want to be clear
do you still have the good condition motor and gearbox? if you do how much for them and how many kms has the motor and box done? is it a complete motor with turbo? what series is it?
  • 3 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
