As for those twin scroll turbine housings from ATP , have a look inside them if possible because some people reckon they're a bit dodgy looking . I've no idea who makes them and no ones said they have Garrett markings on them so anyone's guess .
A .
just received myne yesterday. has ATP cast onto the housing so i assume its made by them. some of the machining leaves a little to be desired and the outlet area looks like a choke point but hopefully it'll work a lot better than the IW housing i have at the moment.
some shitty phone pics. thats a 3" v band flange sitting on both sides to give you an idea of the small diameter inside, very different to the garrett housings which are a smooth and progressive opening from the turbine size to the flange size as in the first pic.
Edited by JonnoHR31
found one. anything in particular you want to see? took shitloads of photos anyway. one more thing i noticed is theres no machined area around the bolt holes for a nut to seat, might have to get into it with the grinder.
http://s224.photobucket.com/albums/dd251/JonnoHR31/turbo/
Is that a twin scroll internally gated turbine housing?
In regards to other questions asked here, the 1.06a/r T4 twin scroll GT3076Rs spool AWESOME in all the cases I have seen - quicker than the .82a/r T3 housing when used with a proper T4 TS manifold. It'd go very very nicely!
Hell, a GT3582R with a 1.06a/r T4 Twin scroll housing spools similar to a .82a/r T3 GT3076 :D
When your fit the CHRA you might want to check how far the CHRA bolts protrude into the volute. Try and grind them back so they are flush with the inner wall if you can.
This is a tip that Full-Race mentions on their web page with regard to the .78 twin scroll housing....it might apply to the 1.06 housing as well.
Edited by juggernaut1
  • 4 months later...
That's good to hear...
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
