ITEM: Mspec R33 1.5 skyline
PRICE: $8000
PICS: uploaded
CONTACT: 0417522192
selling my 1.5 95mdl R33 Mspec due to lack of use...
MODS:
TRUST front mount intercooler (blacked out)
G.A.B fully adjustable suspension all round
G.A.B upgraded sway bars front and rear
NISMO strut brace in front
NISMO plastic grill
NISMO speedo mixed with GTR dash
GREEDY boost gauge
HKS 3" front front 4" out the back
GTR400R style front bar (indicators filled in) no side vents
VEILSIDE 18x8 fronts 235x18, 18x9.5 rears 245x18
the car is a 5spd manual turbo, never boosted, no engine mods except for air filter and front mount,
ive just put a new 400R style front bar on it and i didnt want the side vents or the trailer front indicators, so i brought a bar with out the side vents and filled the indicator holes in for a smoother look. the car has been fully repaint and i changed the original silver color to quick silver (VY Holden Color) cost $3200 to repaint. the car was repainted almost 1 year ago but has no marks,dents or scratches, stone chips due to lack of use. would be lucky if it was driven 6 time in a year and thats only to keep the battery charged and parked up again..
the car has rego expires today and i will sell it with or with out 12mths rego at extra cost..
selling for $8,000 firm.. will pay up the rego for new buy at what ever the rego is on top of 8k
https://www.sau.com.au/forums/topic/329250-fs-r33-series-15-m-spec/
  • 5 weeks later...
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
