My friend says in the txt i got.....
"I f**ked up the axle on my back left tyre and the rims f**ked. Wonder if SAU knew good people that could fix it and do up the other stuff that needs to be done. Going over the the island in the middle of the road f**ked it"
She wants to know where she can take it to get it repaired and what it might cost.
https://www.sau.com.au/forums/topic/329251-friend-needs-her-s14-repaired/
  • Replies 52
Here's the only pic i have. She says you can't see the damage with the wheel off but she says something bends as the wheel goes forwards but clicks when you reverse. She lives in Noarlunga Downs. And NO you'r not getting pics of her.
dude, as i said when you asked me on fb, get her to take it to a workshop and have them diagnose it, itll cost her 20 bones to find out. its pretty hard to figure it out based on a couple pictures taken with a mobile phone.
Yeah i think she's going to take it.
the cast spider hub is broken... to break that its taken a pretty big hit and few or the arms are probably gone also, you could get all those parts and a drive shaft for maybe $250 - I would have them if you need them. You might also need the wheel bearings - another $100.
The thing you need to take a closer look at though is if the sub frame has been bent also, if it had been its a lot more work to replace.
If you go to a workshop I would estimate $500 minimum - but quite possibly up to 2k if they have to repair the sub-frame etc as there could be a full day of labor, all the arms, the strut, wheel bearing assembly, drive shaft etc.
Edited by samstain
how exactly did you punt it into a traffic island?
ha. no shit. only just noticed that. good eye. mustve smacked that island pretty hard.
Edited by scandyflick
was at a stop sign onto a main road and in 1st gear. i accellerated around the corner and it spun out one way. then i tried to straighten it up and it did like 2 full 360's across the main road into on coming traffice (while having my foot on accelerater instead of break)...and the island stopped the car heaps suddenly and took a chunk out of the rim and popped the tyre...the car looks fine and everything... no one got hit...its just the wheel part on the back left of my car
It may 'look fine and everything' but do not drive it anywhere - the main arm that locates the wheel has snapped clean off...
Probably they easiest way to fix it is to pick up a complete hub to hub sub-frame and drop it in there.
There is something strange about the colors in the photo, almost looks like the cast part has been cracked for a long time and gone rusty.
i cant drive it at all...the front two wheels are straight andd the back right but the left one...anytime we tried to move it the spare wheels bent inwards like it was trying to go under the car...but then when we reversed it, it clicked back straight :S
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
