  • Replies 76
Posted Images
Im in the process of ordering some more TV tuners, ASUKA HR2 and HR3s, so anyone chasing a tuner, pm me for details over the next couple of weeks, and so i can add you to the order, cheers, Simon
Hey man,
Any links for both models? Would like to read about what they do :D
https://www.sau.com.au/forums/topic/329266-tv-tunersagain/#findComment-5351676
Basically.. the HRIII can record Digital TV while you watch another program and can play back MP3 + MP4's via a USB input.
Simon,
What's the price going to be on the HR III? Looks awesome, love the MP3 + MP4 playback (including divx and xvid) and the recording (not that you would use it that often but hey).
I assume hooking it up would be identical to the instructions for the HRII.
https://www.sau.com.au/forums/topic/329266-tv-tunersagain/#findComment-5351691
Simon,
Should be about $280 I believe.
https://www.sau.com.au/forums/topic/329266-tv-tunersagain/#findComment-5351740
Brad, will talk to you soon about getting some connector cables for the OEM tuner.
Are they the RCA to white plug jobs (for the factory tuner)?
If so can you get a spare one to go with the hr3 unit please, they are about $70 - $80 aren't they?
https://www.sau.com.au/forums/topic/329266-tv-tunersagain/#findComment-5364926
Im thinking that if the HR3 can record tv and radio it MIGHT record the av inputs aswell. Because I want to be able to have an extra camera inside the car which can record things, just in case my car gets broken into then I will have there pictures. Ha Ha.
https://www.sau.com.au/forums/topic/329266-tv-tunersagain/#findComment-5367100
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
