Sau Wakefield Wrap-up Thread
S13Deviat
 Share
  • Replies 212
For anyone that went off track, or for those that need their car cleaned and brought back to new after a track day, see my signature and PM me for further details on getting a detail!
Special rates for SAU members!
Sounds like everyone had a good day, lots of PB's, including two zeds. Duncan's GTR went well. The Slot Car was getting pumped up ready for the next one.
Curious what was the fast car there?
I ended with a 1.06.6 after the Group 1 & 2 merge.
looks like it was mykk :D
I'm curious to know what Duncan's car was getting around the track.
How much kw is that car pushing mate?
Best is 1.08 in production car form (12psi and 17x8 control tyres). Haven't had a chance to run it at proper boost on proper tyres there
I guess it didn't go quicker than 1.09 or maybe high 08s, unfortunately the timer wasn't working. the focus was really on getting some long runs in prior to the 1 hour race there in 4 weeks.
about 230rwkws at standard boost.
yeah about 10kw less on this motor, it is pretty tight compared to some in the past. ran very well though, even though it was literally only run in on the dyno the day before. But it does make very cool flames
It was great to see so many new faces out there, and a huge thanks to all the instructors who gave their time to jump into passenger seats....hopefully they were able to provide lots of good tips :D
Call Shell... The 33 is a mess... ROFL
I got a new PB on that day :)
So chuffed for you Eddie!!!! Sub 1:10 is just friggin awesome :D Its a credit to the way you steer that thing around the track! I was so impressed and shocked how different it is pointing a FWD around a track..... oversteer.... what oversteer!?!?! :D
Congrats again champ!! :D
+1
This dude does a friggin awesome job of detailing a car!!!
Thanks Ando!
You gave me some good advice on the lines for the last 2 corners. They felt more smooth and natural then what i was using before, and it obviously worked :)
I'll give you a go driving the car next time ;)
Had a nice big screeching sliding off into the grass and mud in session 1 when i hit some coolant or something, apologies to Shell as my passenger........ was fun though!!!!!
haha all good mr moocow! was fun indeed!! :D
big thanks to everyone that mad the day great.. had a ball.. will definatly be going back again and again!
Big thanks to ando who came out with me to instruct for my first time around the track.. was a big help, could feel myself get a bit quicker during the day!!
Looked like a great day peoples! So jealous! Wish I could've been there! Hopefully next time...
I've always been curious to know the times I should be expecting for myself in a V35 and also what to expect for other cars at Wakefield... and from the random posts I've read, some did new PBs - Any official Times posted anywhere?? Can't see any...
If not was hoping if you all can post like below and help me and others to set a laptime goal for ourselves... Cheers!
Car Type: 2004 - V35
Mods: exhaust
Power (approx): 206kw
Wakefield Time: 1:00:00 - I WISH! I've never run it...
It was untimed, as we had passengers :happy:
The people that have posted times did it themselves...
Mods: exhaust
I'm afraid you are going to have to have alot more than an exhaust if you want to get a minute flat at Wakie :happy:
A mate of mine was running 1:16s on his first day at Wakefield in his standard 350Z, I'd imagine a V35 will be similar to this. There are heaps of variables to factor in (driver ability, tyres, condition of vehicle, conditions on the day ect) though so it's a very rough guide
I'm afraid you are going to have to have alot more than an exhaust if you want to get a minute flat at Wakie :)
lol... yeah I know mate. Nothing wrong with aiming a "little" high... Which is why Im curious to see some times posted and type of cars and power and tyres they're running with.
But 1:16s is what I'll aim for. Thanks for that.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
