Sau Wakefield Wrap-up Thread
S13Deviat
 Share
Dave, is that his username cause I just tried to locate him but couldn't?
Here we are Drew...
Unigroup Engineering (where Yavuz is proprietor)
Unit 17/17A Amax Ave, Girraween.
02- 9631 2470 Mon-Fri (Sat by prior arrangement)
  • Replies 212
Yavuz is a deadset legend, he is a master at his work. Every time my car has been there, when i collect it, he throws me the keys and tells me to go for a drive to make sure i am happy with it....... and everytime the car has blown me away.
P.S - If anyone knows anyone with R33GTR/R34 GTR o2 sensors for sale or even non-nissan equivalents please let me know as apparently everyone's having troubles getting parts from nissan in japan??
I bought a Bosch O2 sensor for my R33 at Autobarn not too long ago. Cost a little over $100 and I had to wait a week for the sensor to come in ;). Pain in the arse (but possible lol) to replace without the proper tools
Glad that people are getting the DVD's now. All of them should arrive in the next day or so. Now that people are receiving the DVD's, pic a photo or three of your car and post it up here!
I'll go first.
I'll go first.
Heh I forgot to ask, hows the front spoiler? Was a nasty sounding crunch when you went off the track to test your 4WD system
I think you hear the tyres hitting the ripple strip. The lip is all good, part of the design to give that extra bit of clearance.
Thanks again for the terriffic photos.
Thanks for the DVD full of pics. Some truly amazing shots in there. PLENTY of pics of my Dads Audi, he will be a very happy man when he see's them.
Thanks to everyone who put this DVD full of pics and the video together. Perfect for people like me who had a camera on the day but the battery died after 3 pics D'OH!!!!
Cheers,
Andy
That's not a big off, that's two wheels on the track still!
Off is when you come off the fish hook in an all wheel slide when you've gone in too deep trying to out brake cass so you trail brake wayyyy too long... Lol
Thanks for the pics! Got some pics of mine and it was only out there for 1 session!
sorry the quality is bad because i shrunk them in paint lol
my off
reece letting me drive his because mine broke in the first session
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
