I'll do it this week. Will be purchasing some lock tight and a special key haha.
Just be careful if you reuse the standard bolts, make sure your torque rates are correct and that you tighten them in the correct pattern
I would use new bolts myself
It is just a 12 point 8mm and 12 point 10mm iirc
So BBS would have designed it this way to give you an option. Very clever!
Just make sure you align the face exactly dead center
I re-used my bolts and they still run fine, it is just a matter of not over tightening them
yeah spline bits 8mm and 10mm
Well I've still got my standard bolts, but I went gold anyway. So I needed new :P
Same here when I put the Panasports in, every time I'm on break at old work, used to go to the car park and stare at it, usually have shoppers stare at it as well!
yeah they are definitely a set of wheels which could make alot of cars look awesome i think!
Ive thought about buying some other wheels just to keep the panasports immaculate lol
top level of a carpark on russell street right next to billboards
took like 5-10 minutes to make it up there cos the ramps can be a little steep at times :/
Ah yeah, I know the one.
Tight ass carpark will all the corners.
But you would of had to pay for parking when you leave yeah LOL! Pay money to take a photo of your car :rofl:
Lol I did have to pay! But I was having lunch in the city with a friend so was already parked and took them when I came back to the car lol :P
Im looking forward to some sun to get some nice pics of the purple colour!
Looks great Aaron. There's nothing like attending a meet and getting free "professional" photographs :P
What's that little black thing attached to the front bumper and the fender on each side? If it's holding it all together, I might need one too :X
Lol amen to free stuff! And thanks!
Yeh they are latches holding on the front bar, ripped it off at sandown lol. But don't regret doing it at all. It takes me like 30 seconds to get the bar off now.. There are still 2 screws under the grill so the bar isn't getting stolen either lol
Was like $25 from auto barn
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
