Here is my 'project' car. One day my dream car after I spend a lot of money on it.
Some of you may have seen it (me and my husband) on Saturday at Racepace
Place looks familiar! Seriously listen to these dudes on here / same thoughts as me on the engine build.
First new oil pump, sump mods, water pump, fuel pump - then look at turbo's, exhaust, new engine loom and ecu, intercooler, radiator, oil cooler before opening engine and filling it full of aftermarket stuff. IIRC your car is spot on compression wise.
yes and no....
would be silly to upgrade oil pump and not do custom drains and restrictors... might as well just not put oil in the thing :P
I
Saw it on aus-vip
Winner with black leather, any mods planned?
Haha, of course!
Already got VS-XX coming and trying to make up my mind on what suspension to use to go a little lower.
I've also bought a K-break grill and now doing research on whether it's easier to fit Z33 brembos or z34 Akebonos :D
Haha, of course!
To which car? I just sold a set of Akebono's as I didn't want to run 19/20's.
Edit: Just clicked the link.
Are they the same brakes as the 350z touring?
I don't know, I've only just started reading stuff.
Over in the US, they've put both brembos and akebonos on these cars but I'm not sure how much modding needed to happen. I also read some people over there were having some success with fitting the CZ Performance Akebono conversion kits for z33. Again, not really sure if they were bolt-on or not.
yes and no....
Yep!
Also people under-estimate certain OEM parts.
And do the short cut round.
Haha, of course!
Oh nice will look good by the sounds of it!
Was hoping to go a full k-break kit for my majesta, but those $$$$$ :P
  • Like 1
Yea, K break make nice looking kits with price to suit but they're a lot cheaper than Junction Produce. Love the JP kit for the y34s but they're way too expensive :P
    • full send the cnut, do this   fark the wrapping and/or stick on siet.
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
    • Finally had these painted and fitted and pleased with the result. also managed to source 400R fender badges.
