CBR is being converted to track only, this weekend hopefully..
How does one convert a bike to track only?
Since when has speed capability and noise limited bikes to being unroadworthy?
Remove lights, indicators etc. and replace fairings with cheaper fibreglass items without headlight holes
+ clip ons
If only it was that simple to make a street car into a balls out track one.
Remove lights, indicators etc. and replace front panels with cheaper fibreglass items without headlight holes
don't forget clip (bolt) ons and to stop paying reg+insurance
Yeah always had a bit of a thing for the shape, and being so dam light means mild power like this one has propels it at a pretty good rate of knots ;)
Just working on the looks of this one now with a bit of rice seeing as the engines worked enough for now.
