Actually i lie...just remembered I took some photos the other day when installing my amp...
Have a shop I can use in Dandy now...its pretty cool...
I can detail cars anytime of day or night in any weather now... :D
or anything else I want to do for that matter
10004058_10152322163471499_1108741461_n_
is this the place near showgrounds, used to be a panel shop?
Edited by Dan_J
