if I had of known i may have tagged along lol
lol well we have it every thursday night at the same place. anyone in any car is welcome as long as u dont do stupid shit and we just hang round and talk bull shit :)
wow.
did your dad take it well when you told him like anus?
biker-fancy-dress-costume-xl-158-p%5Bekm
Hes fine with my sexual preferences
600?
Yup
With 'modified' zorst.
Wish I could have ridden something that nice on my P's...
Sounds awesome at higher revs. Made the bike smoother too suprisingly.
Impossibru
Enjoyment:theftability correlation r = .998 p = <.001
Just buy another one man
  • 1 month later...
Hello guys,
Shaun here. I have got this ride for couple weeks now, it has been really fun ;P
It comes with (from what I can tell) turbo timer, full exhaust(no idea about the brand or whatsoever, maybe you guys could help me out), AVC-R, body kits...and I think that's all, rest of the car is pretty much stock.
UPDATE...Just installed my reverse camera and pioneer headunit couple days back ;)
  • Like 1
  • 4 weeks later...
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
