No...as u can see Above the car originally did come with a larger lip...sigh...
Thanks for pointing that out guys, I now cannot live with my car again.
I'm rather pedantic about these things. I didn't notice at first as I didn't have the car following that incident for a good 7 months. Guess I'm saving up another 1700 dollars that that lip cost my insurance company to buy the right one.
Awesome.
Cassandra, I didn't in any way want to offend you, just thought I'd point it out in case you didn't know the difference.
I'd be getting the right lip for your car at the insurance company's expense, not yours...
Either way nice looking car, but personally feel it would look better with the series 3 lip. But be careful, they are easily damaged, I know as I have one and am very careful entering and exiting driveways....
Good luck with it all....
:cheers:
:cheers:
the car is 4wd height currently due to vicpol and needs exhaust overhaul for that reason, which will also happen. I remember what they were like lol but the car was lowered at that point too.
No offence taken but as u well know urself Jack- all the shit that comes with that car is a massive pain in the ass. I'm in a bit of a dilemma with that as I don't want the workshop I went to to get in trouble for somethinG that is nissan's fault. So I've just emailed Jesse streeter to see if anything can be done for less than Nissan aus' price.
Nick - the mere fact that I get asked web people see it if it's 'really a series 3?' is enough reason to need to get te right part... It'd be like putting an evo 7 hood on an evo 8 and have people say is that REALLY an evo 8? Lol
lol you would be surprised how many ppl put evo 9 parts on 7's and 8's
and all the time i get asked if my car is a real evo lol
i would leave that lip, looks better than the series 3 lip because its smaller and you can lower the car more as well
in the end its a lip, yours is in gc.... is it really worth spending $1700 on a cosmetic part that isnt broken?
this is common sense. i like.
Hey Cass, I found this for sale :P
R33 GTR Series 3 Front Bar & Lip
that thing is a rip off i mean its obviously cheaper than the lip alone but the condition looks crap seen better ones for the same / less
Gonna apologize to Grant at any point? I think this is the second time I've read you have a bit of a go at him for questioning the lip on your car.....
fair point.
imo id leave it slam the car and forget about it, will look tits slammed
I have a shit driveway due to apartment building...can still have correct lip and drop it again and be able to get in though. I'm a stickler for everything a out the car being right or I lose my cool somewhat badly and obsess over the thing that's wrong :P
yes, the questions bother me as u can see above. The car shouldn't have to defend it's honor constantly because Nissan can't order the right bloody part...
And I believe I've admitted to him being right, that's moreo f an apology than he'd get from most guys...but ok, yeah I'm sorry for losing my temper but his need to harp on about how ts wrong pisses me off about as much as it's being wrong does.
I wouldn't have a clue how much it's worth lol, I just thought I'd post it up for Cass :P
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
