Since we're all doing it,
Here's a peek into the garage, although they don't all fit in the garage.
The Fat girl, the Daily, and the Crotch Rock.
Naice bike! Swap that exhaust for an Akrapovic F/S though, trust me :P
As for my latest:
Um, whoops...
'05 SLK350, Manual, 35,000km. Don't ask me why, because there is not one single reason that I can think of...
That photo was from the previous owner... this one is from tonight, picking up AMG rims when I head to the US in July:
As for my latest:
Um, whoops...
Ok so you sold your R34 GTT, bought a VE SV6, a dirt bike and now a SLK?!
Whatever happened to the R34 GTR plan?
You better not be trollinz!
:P
Thanks gais... yeah it was pretty unexpected. It's more and more fun the more I push it.
Did definitely think of the GTR. And it pains me that I did not go with a Skyline, but really the idea of this car spurred from a day not so long ago when I was driving down to the Peninsula in the Ute and though "This is a bucket of shit. What I would like to be driving is something similar to a Lotus Elise" And shazam: SLK. There were many pros and cons to compare but I think the main factor that has stood out since driving the SLK is the comfort when you're treating the drive as a daily. If you ask it for some beans it delivers and feels soooo good but other than that it is the most comfortable snuggley car on the road. I find that Jap cars are incredible but in particular the Skyline drives heaps better when you're going fast, which is awesome but I like to have my cake and eat it too. Particularly over speed bumps.
Don't despair though... At this rate I should be picking up my R35 GTR in, hmmm, 3 months? :P
End of review.
Hahah.... yeah, funny you say, just couldn't decide on whether to go a Full Akro, Full Yosh, or Slip. And I wussed out thinking that it was just going to be painful on the head to hear that think humming the whole time. Turns out I only really use it on the track so really didn't matter, then i heard one, now I'm thinking again......
And gonna need a little more of a run down on the Merc I reckon, missus was going to buy one and I told her she wouldn't like it and tried to get her to settle on an Elise......... she didn't have a bar of it once she saw that it had no carpet. So she's still in a little GTI as well. Who the hell cares if there's carpet. Oh well.
End of review.
lmao as bad as me! i have been through 3 cars in about 9 months.. going onto my 4th in a couple weeks thumbsup.gif
Yea but her cars were decent
My cars were decent, non of them broke down, all of them drove straight (except for the 33. Leaking time bomb)
Could have went a whole lot worse and coated it in some fluro :)
Edited by Mohsen
I have a full Akra on my Blade and it is the sweetest thing you have ever heard ^_^ but mainly it just makes the bike perform soooo much better. Definitely worth the purchase. You can also wear ear plugs which can help, especially on the track, heaps better for concentration.
What tracks do you ride at? Been out lately?
No carpet? Has carpet? What you talkin' 'bout?
This thing moves, it's awesome. 200kW with such a light body and the Merc handling... Everything works well, the clutch is perfect, the gear box is perfect, the throttle is perfect and the breaks are great. It's just a pleasure to drive ^_^ Plus heated leather seats and hard top convertable (always a bonus). I also like the fact that you're pretty much sitting over the rear wheels, can't wait to take it to the skid pan!
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
