http://www.skylinesaustralia.com/forums/post-a307564-
That looks MINT!
Love the bonnet, could you possible tell me where you got it from?
Edited by El_Mutto
Thanks dude. Yeah been keeping an eye out for a front lip. So hard to find a good looking lip, only one around is the EastBear. Really wouldn't mind something different though.
Yeah I liked the old rims also, but I was getting out dished by my Honda mate's so decided to go concave rims instead lol. Not too sure what rims I should go for next. Was thinking AME TM-02
I like the TE's, they look like they're 17's right?
A mate of mine just recently got AME TM-02's, only then did I realise that they look like the rims I just ordered, Enkei Rpf1's. A bit of research and I found out that the AME tm-02's are made by Enkei, pretty much the same wheels.
Yeah TE37's are 17x9+22 all round.
Had a set of AME Nobleys previous and realised that they were made by Enkei lol. AME TM-02 in aggressive offset looks so good with massive concave though :thumbsup:
Can I borrow your TE's :) look sweet in 17's with concave!!
lol EastBear looks great, but was hoping to find something different
18's looks good but I think it looks a tad too big for the GT-t. Plus I like the curved spokes :)
I would if you still had the XD9's :thumbsup: Your car looks awesome with the XD9's
Edited by john-e boi
nice ride john e boi i like the bride seats rear wing and wheels looks tuff :mrt:
i wana get a front lip for mine east bear looks like the one i have the side skirts and rear pods
need to finish her off
wot u think i should leave the front with melb roads being so f!@#$t up and that
maybe de-badge the rear and east bear aero bonnet
both east bear front bars and bonnets
:D
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
