hey guys
so ive limited the my choice of wheels down to two.
im not racing on them they are purely for street looks
being 4 stud im limited ... but i have found some i like but need help choosing haha
so first ones are the koya drift teks (i know there copies of the uras and they are copies of bee*r's)
andd
Koya Rg teks (apparently just been released)
ill be going 18'' and probly +34 offset ... ive been told offset doesnt change the dish.
so ive decided to turn to sau for opinions.
Edited by aussietroy
https://www.sau.com.au/forums/topic/329289-need-help-picking-rims-for-my-32/
haha, i like the dish of the lip on the nismo LMGT4's but they are too flat in the spokes imo ...
thats why i like the drifteks but thats just me
im not sure if the rims will get lost with silver on silver or not
but then again the darker ones will probly get lost at night ...
yeh im leaning more towards the drift teks
im abit funny on the rg teks ... there new so it would be something unique ....
but i have always liked drift teks and all the rims that they are copies of haha
Go black or bronze in wheel colour and that should stand out to give some contrast.
Another wheel you might want to look into, Bee*R Racing Wheels.
yeh they are nice, but im pretty sure there discontinued and pretty pricey.
getting in 4stud is pretty hard and redrilling is too much effort.
going the cheap option haha
i think im gana go the drifteks
there copies of bee*r's and Lmgt4's.
done a fair bit of research haha
mate..
i know you get asked this all the time.. but why arent you going japanese??? are you SURE you cant afford it? like ACTUALLY sure?
pm me... i may have something for you... and yes. four stud is hard.. but not impossible!!!! if you want jap... get jap.
you never know. it may work out cheaper as a wheel n tyre package... hit me pm if you interested.
im assuming youre fairly new to these forums. quick lesson for you. if you buy cheap. you buy twice. howevr i may save you money anyway.
STOP THE COPY.
Drift Teks it is man!
Get on it.
:happy:
i know from research that jap wheels are better quality and stronger and stuff but im not going to be racing they will only be for street use.
The drift teks are fair cheap and look good.
what would be the best offset to go without having to modify guards ??
thanks heaps for the help guys.
    • Yes there is a front and back insertion point on each side, each point is tubed with supports into the car and tied to the cage/ floor mount point
    • Is the jack stand system tied into the cage somehow? Upgrades look goooood 😍
    • Big updates, tons of work and $$$
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
