Hey guyz,
i needed some help connecting the turbo wire to the car?
i have installed alarms before and i know bout them, Just not sure where the turbo timer wire needs to go.
I called Autowatch to ask them how i can turn on the turbo timer and they sed i need to wire it for it work.
So please somone help me out.
Cheers,
Vish.
https://www.sau.com.au/forums/topic/329297-need-some-help-autowatch-turbo-wire/
you are not listening.. as I told you this morning it is a wiring and setup thing on those. get it wrong and the alarm WILL NOT work and there is a VERY good chance you will destroy a module - pay someone to sort it out for you. otherwise live with out it.
I got the 456 premium fitted by Action Alarms. Do u think i should get it done by them?
What i am trying to find out is if the guy connected my turbo timer wire or not? as i did not know it had one when he was doing it so i didnt think of asking him.
I called action alarms but they sed they are not sure as the guy who fitted is a contractor or something like that.
anyways i will check with alberts in cannington.
Cheers.
its not wired if it was then you would have to push a button to shut it down.
I replied in your other thread too, but to further this comment...
The timer will only keep the car running when the ignition is turned off if you have had the ignition on for 2 minutes or more. So... driving for more than 2 minutes, or if you just go to "ignition" and not start the car, leave it for over 2 minutes, then turn the key to "off", it SHOULD keep all the ignition lights on the dash until you force it off, or the system reaches the pre-defined countdown to automatically shut it off.
If the system has the function (which I know it does) the installer should have hooked it up. I'd do the test, and if it's not working, insist that they finish the job. Why would you pay them for a system with a built-in feature if they're not going to set it up? =-]
(see my other reply in your other post too)
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
