This is an EOI. Looking to buy a new car, If it sells it would help me out giving me a higher budget to spend :D, not a necessity to sell it but if I don't get close to the asking price I'm going to keep it :/. $15500
To all that dosen't know what a GTS-4 is: Its simply a GTST with a GTR chassis and running gear. So yes its equipped with ATTESSA-ETS. It does not however come equipped with HICAS, but with most of us we don't like it anyways so thats a bonus XD heheheheh.
The GTS-4s were alot more common amongst the R32s and not so much the R33s. This car was originally N/A and only came in 4 stud with crappy brakes. But I fixed that with a heart transplant from a Stagea RB25DET + a full 5 stud conversion with R33 GTST brakes and rotors and is now one of a kind car ^^.
This is a rare and very clean example with some tasteful mods to suit.
Year:
1997
Make/Model:
Nissan Skyline R33 GTS-4 Series 2
KMs:
122xxxkms (motor has ~2000kms less than body)
Transmission:
Manual
Engine:
Series 2 RB25DET from a automatic Stagea, so motor and turbo hasn't had a hard life.
Engine Modifications:
Have only ever ran BP ultimate and 100% synthetic lubes. Serviced every 3500-5000kms
As above RB25DET swap
Apexi power intake pod
Cold air intake
Air box
HKS SSQV
FMIC
TurboTech Boost Controller (set to 12psi)
R32 RB20 10psi actuator
3'' bellmouth dump/front pipe
4'' 100Cell High flow metal core cat
3'' RS*R Cat back
Genuine Walbro Fuel pump
ECU Remapped by Toshi
NGK Iridium plugs
Nismo radiator cap
New engine mounts
Engine damper kit
New NTK 02 sensor (not fitted, still have it in box)
Driveline/suspension goodies $$$$$$
Royal purple 100% synthetic gearbox and diff oils.
Full 5 stud conversion with R33 GTST brakes and machined rotors
Bendix Ultimate pads front and rear
Exedy Heady Duty Sports Organic Clutch
Xtreme lightweight Chrome Moly Flywheel
JJR Front Strut brace with Brake brace stopper
R33 GTR Rear strut brace
Sydney kid Suspension set up
Bilstein shocks (height adjustable)
Whiteline coil springs
Whiteline Heavy Duty Rear swaybar (adjustable)
Whiteline Subframe lock n align kit
Whiteline Front Castor bushes (adjustable)
Whiteline Front Upper control arm bushes (adjustable)
(Reason I left out the front whiteline swaybar was because I wanted to induce a
bit more oversteer for a bit more fun :))
Wheel/Suspension Alignments done East Coast Suspension. Paid a bit more to have it done
professionally and correctly the first time.
Wheels
DTM Rush 18x8.5 9.5
Tyres
Kumho KU36, (equivalent to semi slicks), Front 235s, PHAT rear 275s, (Rolled guards) ~60% tread left
Equipped with ALSD
Suspension set up is very firm and coupled with ATTESSA, car handles amazingly well
Cosmetics:
Interior is immaculate, Paint work washed, waxed and detailed regularly, always parked under shelter.
Full Mspec factory option kit, Lip, skirts and pods. (All Genuine Nissan plastic no fragile
fibreglass copies.)
Headlights replaced with Brand new Genuine ones direct from Nissan. about $600 EACH!! OMG
there absolutely CRYSTAL CLEAR, no yellow, dull, foggy crap you get with aged ones.
Autogauge Smoke Series Boost gauge
Autogauge Smoke Series Oil Temp gauge both installed into DIN
Alarm, central locking, immoboliser
Window Tints
Audio:
Genon 7'' Touchscreen CD/DVD player (Flip)
Sony Xplod 6'' 4way Front speakers
Sony Xplod 6'' 2way Rear speakers
Sony Xplod 12'' Subwoofer
Jensen Amplifier 500w?
Pretty sure I've missed some bits and peieces, has about 5months rego left.
May not have the heart or looks of godzilla but certainly has got its feet.
Car has been much loved and cared for. Would really love to see it leave with someone like minded. Honestly I do not want to sell it to some cash loaded hoon with more balls than brains and decides to total it the day after.
If interested or want more info/Pics just shoot me a PM
Thanks guys
Edited by OoskylineoO
post-40593-1279365510_thumb.jpg post-40593-1279365527_thumb.jpg post-40593-1279365545_thumb.jpg post-40593-1279365561_thumb.jpg
Heya, Just thinking about your car. Looks great and sounds like its in great condition. I am not going to tyre kick or knock your price. Im sure it is well worth every cent you are asking. i would hate to have tried to afford this car a few years back. I have only 14,000 in cash, thats all the money i have :rofl: sadly...
Is it worth talking to your further or not?
thanks lots!
I am looking at some others too, im a lil confused with lots around but ive found it difficult to find a good car so far....
PM sent thanks
Heya thanx for the reply and yer lets see what happens im not in a rush to buy the first car that comes along so if and when u r ready we might be able to talk:)
Good luck dude thanx again.
  • 3 weeks later...
  • 3 weeks later...
  • 2 months later...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
