Hey guys, as title suggests, I got my aftermarket ECU tuned today. WOW is all i can say, the difference in torque and power is unbelievable.
From lookin at the Graph, ive gained 20rwkws + in mid range over a number of spots, and a total of about 10rwkws in max power. This is all done using same boost level of 13psi.
On the road, the car is breaking traction in 2nd which it didnt used to do. Acceleration feels great and the seat of the pants feeling is definately more.
The car has been tuned to an excellent AFR of 12:1 and they put in about 10deg more base timing. The dyno was run in non-shootout mode, so i would assume that if it were shootout mode, the figure would be in the 200's :).
So rounding things up, the car is alot more driveable, there is power increase everywhere and the power curve is alot more smoother which is nice.
I still have to get my ebc workin so that i can hold 1bar of boost. ATM the bleeder is getting to 15psi, then droppin to 13psi. I also have an adjustable cam gear exh side gettin here soon aswell as finishin installin my CAI and partition.
Current mods are Trust front pipe, 3inch exhaust, HKS pod, GTR intercooler, unichip, and bleeder set to 13psi. Also I have heatwrapped all piping under bonnet, and daim, those temperatures are now kept down. It wasnt even hot after a huge burn thru the hills :)
So in summary, I think the Unichip is very underrated. It was perfect for my needs, and I am very happy with it. :headspin:
R31Nismoid: I bought the Unichip of ebay for $550. Tuning was $250.
Basically it was an absolute bargin. And SAFC II which would have cost more has not nearly as many functions, as Unichip can do somethin like 400 ign/fuel points.
Strutto: Im running a stock turbo, well it says nissan on the cover. By Front pipe, i mean after the stock dump, the pipe after that that connects to the cat.
Congrats Dean, nice result. Did they say why were the runs done in 2nd gear? It wont effect the peak power figure anyways, and is still good for comparison as the first run was done in the same gear. $250 for a full tune is a good price too, wish power fc was that cheap:p
Installing an Adjustable Ex Cam Gear is gonna easily crack the 200rwkw mark before you get it retuned. Im no expert but are your AFR's still all over the place alittle ? (I honestly have nfi with AFR's).
Have you got pineapples in the rear ?
Also if its the stock turbo how long do you plan on running 15psi thru it for ? :wassup:
Steve: Id definately say dyno runs wer done in 3rd. Have a closer look at speeds.
Benm: The AFRs are really good. Looks like a consistent 12:1 which is optimal for a Turbo charged engine. Im actually running 13psi atm, but wanna run 15psi. I dont gun it much anyway. I still gotta do some more investigating into it thou. Also i have Tien HAs, no pineapples, but asky bushy2k, i have no trouble launchin hard ;)
Bushy2k: Bring it on bro, I still got some more things to put on, so the car will be quicker. It does feel alot quicker. Heaps more torque.
I was always very impressed by my Unichip (when I had it) It's only when the stock ECU reaches its limitations does the Unichip become an issue. At the time (3yrs ago) no Unichip agent (including APS) could confirm for me that the Unichip/stock ECU combo could work via a Z32 AFM? At ~225rwkw the Unichip could no longer prevent massive timing reduction via the stock ECU sensing a seriously maxed out AFM voltage! It was for this reason (& a few others) that I removed my Unichip & went for a fully programmable ECU.
Dean you may find your car doesn't display the same characteristics as mine did (I also had a much larger turbo & cam gear adjustment at the time) but as airflow gets higher, via improved breathing, your AFM will reach the same point mine did. Your stock ECU will be the deciding factor. Mine pulled 15' timing out 3x in one power run. This resulted in a peak of ~225rwkw with a number of 15-30rwkw dips, & a pig of a car to drive ;) Think, 'good ol' R33 flatspot,' & then you'll know what I mean.
If someone has successfully got a Z32 AFM to work with the stock ECU (don't see why not) then you'll have no problems :D
EDIT: Just had a good look at the dyno sheet mate. Firstly, congrats on the power. Second, your before & after power curves are the same as mine were! :D I asked Turbo Tune at the time (only real option for tuning Unichip in SA - unless you head to Port Augusta) if they could do a Z32-stock ECU set-up, they weren't sure but would give it a go! I didn't bother. Ask TT why they couldn't completely get the rid of the small dips in your power curve? I'll be interested to see the answer.
Nice result.
Just a couple question though.
1. Why was the run done in 3rd and not 4th?
2. Why wasn't the run done in Shootout mode?
3. One of the dips in your power curve should be the NVCS, what is the other due to?
Cheers
Paul
Paul, when I had my car dyno'd, they told me they had to do it in 3rd or they'd hit the speed limiter. Also, isn't shootout mode really just there for comparisons? If you're just after a tuned car then why would they put it in that mode? I know I personally would like it tuned in shootout mode so I could compare, but some tuners just don't care about that, they just care about the before/after.
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
