Braided lines and a master cylinder stopper will fix all your probs with some new fluided added.
Every car I drive feels like the brakes are spongy in comparison.
Brakes used to be perfect. Bit well the moment you touch the pedal. Problems began after I fried the brakes on a track.
The pedal does nothing until about half travel.
I have braided brake lines, QFM A1RM pads, new discs, master cylinder to strut stopper.
I removed and drained the fluid from all four calipers, refitted, bled - no difference.
I rebuilt the master cylinder - no difference
I rebuilt the front calipers - no difference
I bled the system no less than 10 times including the ABS unit, in the order the manual recommended - no difference.
I lifted the car in the air, an assitant "drove" it while leaning on the brake pedal to trigger the ABS while I bled it - no difference
When I manually energize any of the three ABS servo solenoids and the fluid return motor, the pedal goes rock solid and can't be moved at all. This means the master cylinder is perfect and it's not firewall flex. It's ABS servo or the calipers have gone soft.
Hence I'd like a damaged/leaky ABS unit to investigate the problem. Somebody must have one, i've seen plenty of threads where people have replaced their leaky ones.
Cheers
Edited by Bozz
Lets just say this isn't for the inexperienced, there are hundreds of parts inside. If you can rebuild automatic transmission valve bodies or an engine, you'll probably be able to do this job.
To reassemble it will require complete cleanliness and complete accuracy - a single speck of dirt, a missing check ball, seal or incorrect re-assembly could result in no brakes or brakes locking on and not releasing....
Next week i'll acid dip the parts, get all the replacement seals and reassemble it.
  • 3 weeks later...
WOW!! Everybody I speak to won't go near it because they are too scared to get it wrong. Really interested in how you go with this, I am in exactly the same boat as you, had to remove my brake booster stopper because it was accentuating the ABS unit leaking. Before that nothing I did could get rid of the spongy brake pedal.
Read a thread about someone rebuilding the ABS unit with new o-rings, had a spare/leaky ABS unit lying around from the first time it started leaking, got all the sizes of the o-rings from the thread and tracked down a supplier that could supply the correct type that are ok for use with brake fluid, bought 3 complete sets just incase I wanted to fix the other one & sell it or needed some spares. 6 months later they are still sitting in the zip locked bags on my desk.
Can you please update thread with any further info you have?
Cheers
Rob
probably a wise move in many cases. brakes are a very simple pneumatic system, ABS is a very complex pneumatic system.
Hey,
While its apart, I'm trying to draw a 3D exploded view of it in sketchup - there is absolutely no information on the interwebs about how this particular NipponDenso ABS unit operates.
I'm 90% sure the solenoids have three modes (build, maintain, release) instead of just two modes since there are three in/outlets (two at the top, one at the bottom) but I need to establish how to trigger them out of circuit. When time permits I'll hook up my digital storage CRO to two of the ABS solenoids and see how the ABS controller drives them. Google told me that some Toyota's use three mode solenoids but I can't find any pictures of them to see if the solenoids are the same or not. Then I'll be able to build a controller circuit to trigger and bleed the ABS modulator properly.
I dont think the ABS unit is difficult, just very time consuming and you have to triple check everything. I took photos at every step of disassembly so I shouldn't have dramas reassembling it. The only thing slowing me down now is lack of time
Yeah fair enough, rightly so, all bar one bearing place I went to wouldn't even sell me the EPDM (?) o-rings after I told them I was going to attempt to rebuild my ABS with them. Guess people are too scared of litigation these days.
Sif I could somehow blame them if they failed, I think anyone attempting this knows the risks if they get it wrong, I def wouldn't be blaming a supplier for faulty, unqualified workmanship.
I tried rebuilding my ABS using the EPDM o ring list that was on this forum. I had a big fail with a lot of leakage. Most of the original seals have custom cross-sections (few are orings) and i very much doubt that it would be possible to get it properly sealed unless you can get the real seals. But - if you can get a set of proper seals please let us know!
Thats really disappointing to hear Adam, I was really hoping someone had a success rebuilding one of these. I really want to keep my ABS, no matter how crappy it is compared to modern day systems. Mine only seems to be leaking from the top, I wonder if I can leave the rest alone and just replace the o-rings in that area that have failed? I have no idea as to how the thing comes apart, was thinking about documenting it so I could put it back in the correct order but never got around to it. When you say you had 'lots of leakage', over what period of time and were you still able to stop the car? Or did you have no pedal whatsoever?
Cheers
Rob
Once you pull the body apart, you seperate the high pressure seals between the solenoids and machined aluminium upper and lower bodies. You wont get it to seal again without replacing the seals. Unfortunately, the bottom seal shape appears to be made of unobtanium and you'll have no hope of getting it back together, sealed, without replacing it.
Work on a spare like I am.
Cheers
I got pedal pressure but it leaked worse than when I pulled it apart. You might have better luck, but IMO some of the seals from the list arent quite the right size even if you leave the shape question aside, and IIRC there were a few missing from that list.
I checked it as soon as it was reinstalled and bled, and pumping the pedal hard was enough to see the telltale wetness. I bought another second hander that looked good, but it also has a small leak. I'm thinking that the ABS manufacturer might be the best place to get seals from, if they're still available. I would like to have another shot at rebuilding, but I lost motivation...
is it a consistent half way pedal feel? is it normal when it gets to half way?
try adjusting the brake pedal pushrod that goes into the master cylinder, i had to do this on my old s13 to get the pedal working correctly
Hi
You seem the type of person that wants to do it for the challenge; if you need a back up plan I have one in good working order for sale.
Regards Taylor
0408 188 777
Bit late unfortunately - I picked one up in good working order for $25 a few weeks ago and it's in my car now.
Thanks for the offer
Hey,
That's exactly how it feels but in my case, it's not the pushrod:
There is air in the system somewhere, I just can't figure out where. That's one of the reasons I'm pulling down the ABS unit and learning about how it works.
I've emailed NipponDenso to see if they'll give me any info on the unit although I dont think they'll reply.
Cheers
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
