  • Replies 41
Sorry, everyone talks about it I'm not sure wat it is?
Combustion gasses leaking past the piston rings. All combustion engines have blowby....it's 'excessive blowby' that means your engine MAY not be healthy. There are various other reasons for blowby including detonation (or hitting the limiter) and not really excessive blowby but gives the same result - incorrect plumbing of catch cans causing pressure build up in the crank case
https://www.sau.com.au/forums/topic/329323-what-is-blow-by/#findComment-5352027
What are signs of blow by then?
https://www.sau.com.au/forums/topic/329323-what-is-blow-by/#findComment-5352036
All engines has blow by. You means signs of excessive blow by or indication of engine failure?
If that is the case: Lots of oil throwing out of breathers, Poor engine compression, Engine noise, oil soaked spark plugs and etc.
https://www.sau.com.au/forums/topic/329323-what-is-blow-by/#findComment-5352184
Heavy breathing......if you take your oil filler cap off and the motor is choofing hard [thee will be some blowby but you should be able to tell the diff]. If you dipstick keeps popping out, if you are using heaps of oil, if you are leaking oil out of the sump and/or rockers, if you have a burnt oil smell, if you have oil in your rocker tubing that drips out......there's probably a few I've missed.
https://www.sau.com.au/forums/topic/329323-what-is-blow-by/#findComment-5352187
This can be misleading, its hard for a novice to know the difference so I would not advise this often.
Comp test and leak down are the most effective ways of testing for signs of wear that would result in excessive blow-by. Realistically if you are burning lots of oil, you can fit a catch can to try and rule out the turbo, then you can start thinking about blow-by.
https://www.sau.com.au/forums/topic/329323-what-is-blow-by/#findComment-5352281
i remember seeing this r32 gtr begining of this year, at a first glance car looked neat, had it idling until it was warm and i took the oil filler cap off, it wasblowing white air/mist as high as the bonnet ! was making a "choofing" sound aswell...never seeing blow by that bad before..
https://www.sau.com.au/forums/topic/329323-what-is-blow-by/#findComment-5352767
I checked out an S15, full service history for 120thou k. Everything looked great, took the oil cap off and dear son of rajab. The car couldn't idle, on the verge of stalling, and it was blowing oil drops out that high it covered the underside of the bonnet, and even made its way onto both front gaurds :down:
However, I've noticed many SR's have loads more blow by then any RB I've encountered.
https://www.sau.com.au/forums/topic/329323-what-is-blow-by/#findComment-5353363
Many of you have absolutely no idea what 'excessive' is.
If you take the oil cap off any of the nissan turbo engines, the engine should drop in idle or nearly stall. They are a sealed engine. The cylinder head is SPLASH lubricated so it is meant to throw oil around there.
Fumes coming from the rocker cover breathers or out of the oil cap means nothing. The engine has to breathe. If it doesn't, bad shit happens.
The most annoying thing to hear is ppl going on about so called 'blowby' because when the car is on the dyno, fumes were coming out of their catch can breather or from their cover breather.
https://www.sau.com.au/forums/topic/329323-what-is-blow-by/#findComment-5353471
I hear you. So explain to us your opinion of "excessive" is ?
https://www.sau.com.au/forums/topic/329323-what-is-blow-by/#findComment-5353528
Impossible to explain it. It's something you know from seeing hundreds of cars over years of experience. Most ppl only see one or two and don't really have anything to compare it to. I'd be happy to take video of a 'normal' one so everyone can see what that looks like.
But, it's not like I can give some sort of measurement of gas flow or a quantity of fume lol.
You'd know from your experience with tuning anyway....why are you asking me?....or is it more for the readers?
https://www.sau.com.au/forums/topic/329323-what-is-blow-by/#findComment-5354082
errr... Think its best i walk away from this one. Should have known better then to bother with someone with an attitude like that.
Wasn't having a go at you mate. Just saying there is no practical way to type in text how much is too much. I was also pointing out that I assumed you would know how much is too much as you have a lot of experience especially with cars on dynos.
https://www.sau.com.au/forums/topic/329323-what-is-blow-by/#findComment-5354739
my rb30e+t (high comp) is a massive fan of blow by lol. pops the dip stick out all the time, oil in the intake, fouls plugs, oil even seeps out of the sump and around the oil pump now aswell.
putting a new rb30et in this weekend and pulling the old block down to build a 25/30 if it is still any gd :P
https://www.sau.com.au/forums/topic/329323-what-is-blow-by/#findComment-5354763
    • Thanks for the info GTSBoy, legend. If there is no downside i'll likely just get the larger bosch units because why not... I remember hearing stories about people washing their bores with fitment of too large injectors way back when, which i guess has made me shy about it now. But happy to know it shouldn't be an issue. Ozdavroz, the little rb20 is a lot of fun- now that i have a little extra funds and time i am very glad to be tampering with the ol girl again, after so long. More RB20's on the road the better. Cheers, Rowdy
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
