Victorian R32 Owners, What Have You Done About The Shocking Headlights We Have?
Well, I have had enough of my terrible headlights, standard projectors with good globes, max adjustment and still cant get a decent beam out of them. Ride height being 345mm/345mm I think is my issue(rake). My height is legal, the rake is required until I re-do my suspension set-up.
Has anyone been in the same boat and come up with a legal solution?
Removed the cover and fitted some replacement Narva or similar ADR approved low/hi beam spotties etc.
-Ryan
My projectors are perfectly fine with what ever random halogen globes. But I have gone to HID now the same with my R31, although not legal.
Your headlight lenses aren't dull are they?
yeh my projectors are good, when i first got it they lenses were dull then i got the contacts clean and made them perfect and also made the head lights look alot better
haha my old ones :woot:
OP you could go HID's heaps brighter, but not legal
haha the r32's (with the projector bulb headlight design) are known for poor lighting. I ended up buying some super-dooper phillips diamond crystal vision globes. Strongest range from Phillips and do shit all on the streets haha
I think your old ballast's have died :woot: There sitting in the garage, the 31 and 32 have different HID kits laws.
I pulled the light beam cutoff out of my low beam lights to give more light. Quick and easy mod and works. They still aren't blinding like the Euro car so its ok in my mind. Not legal but isn't to bright to other drivers as they are average headlights to start with.
find some cheap 32 sedan headlights (non projectors, like the n1's but nop grill clips)
they are h4 globes and heaps brighter
Thats what I was thinking, just didnt want to create demand by saying all N1 lights are, is sedan lights with a 30$ clip!
I think your old ballast's have died ;) There sitting in the garage, the 31 and 32 have different HID kits laws.
;) can u explain these "different" laws?? I was under the impression that after market HID kids are illigal because although we have projector headlights we dont have
a) self leveling balists
and
b) headlight water squirters
I could be wrong tho, I really really want HID's coz i cant see shit outta the front of my gtr at night.
:( can u explain these "different" laws?? I was under the impression that after market HID kids are illigal because although we have projector headlights we dont have
and
Your 100% right, i meant to type ''lawls'' not ''laws'' hahaha :mad:
i did exactly that to my 33, made the light look HEAPS nicer and night beam better too,
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
    • It will be salvageable. It really doesn't matter what is damaged. Opening up a 30+ year old motor for a rebuild immediately means a complete rebuild of the head anyway. Damaged valves just means an opportunity to put in some nice new ones. And in the modern day, why would you not throw at least a nice set of pistons at something. And if you're doing that, why not rods, and ARP fasteners, and so on.
