Fs R32 Gtr 89 Model, Quick Sale
Item: R32 GTR 89 model 122,000kms on clock
Item Condition: Clean
Reason for Selling: Spending money on Wedding and house :rofl:
Price and Payment Conditions: 22000ono
Engine-
Rebuilt motor about 11000kms ago parts including
cp pistions and rings
Acl race series bearings
Acl race series metal head gasket and inlet gaskets
ported polished head matched manifolds
rev lightweight rods
stainless steel valves
shaved head block etc
fully balanced bottom end crank etc
gates race series timing belt
all new gaskets
jun bronze valve guides
Jun oil pump
Jun oil pump crank collar
Cam plate covers
Baffled sump
Oil restrictors in the block
New genuine Nissan water pump
new Garrett GT2860R5S Turbos
new radiator
all new rubber hoses
Greddy hard pipe intercooler kit
K&N pod air filters
Splitfire coil packs
Apexi Power FC computer with hand controller
E-boost 2
M's torque split controller
Cooling-
19 row oil cooler with relocation kit
Fuel-
Sard 720cc injectors
Sard in-tank fuel pump
Hard wired fuel pump
Turbo Smart adjustable fuel pressure regulator
Wheels-
18 x 10 + 20 rays engineering volk winning wheels
With kuhmo exsta spt tyres 275 x 30 x r18 70% tread left
Brakes/ suspension
Rda passivated 324mm rotors front with red stuff brake pads less than 500km old
Drilled 297mm rotors rear with 70% pads
New Abs unit, no leaks
New brake fluid changed 150kms ago
KYB Buzz adjustable shocks with springs
Apexi front strut brace
Driveline-
Os giken StR 2c twin plate clutch rebuilt 500kM ago
Light weight chrome olly flywheel
Redline shockproof oil used in gear box changed 200kms ago
Exhaust-
Apexi power extreme ii cat back
Stainless high flow cat
Others-
H3c HID headlight kit
New diff oils front and back 150kms ago
Original skyline carpet mats front and back
4wd/2wd switch
New radiator coolant and engine oil
Plenty of $$$ spent, and a very quick car.
Car produces 285kw at all four wheels @ 18psi
4th gear is a little notchy sometimes.
Interior is extremly clean with no rips, tears etc.
Front and rear seats are like new.
No test pilots/ joy riders, genuine buyers only
Has 1.5 months rego
Very clean panels, doors etc, very minor parking dints and no accidents.
Rear bar is fading a little.
CALL Rob on 0418 686 962
Edited by RBFan
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
