hey guys,
I finally got hold of my first skyline, a R33 GTST. Its a 1997 model, SII coupe. I was just wondering if there is anything special i should know, along the lines of what fuel to use, maintenance, etc. Any special knacks to keeping it in good shape?
Thanks guys, any tips are much appreciated :rofl:
https://www.sau.com.au/forums/topic/329372-r33-gtst/
Thanks guys, anything i need to know about warming up/cooling down turbo? Ive been driving a Turbo MX6, but its so primitive i was told that the turbo doesnt need any special care, it just kinda does its thing :rofl:
https://www.sau.com.au/forums/topic/329372-r33-gtst/#findComment-5352548
A friend was given some good advice when he bought his car. They told him there are 3 things you need to know about skylines:
1) Don't accelerate around corners.
2) Don't accelerate around corners.
3) Don't accelerate around corners!!
It's sensible advice. Skylines are tail-happy cars on the throttle because they are very neutral to begin with. They have not been designed to understeer to keep muppets safe like many other RWD cars.
I would highly suggest a defensive driving day or a skidpan day to get aquainted with the car and how it handles. As other have said, use 98 RON fuel as a minimum, service it every 5000km, fit a proper alarm/immobiliser, and warm it up gently before thrashing. Start it, wait 10 seconds and drive off. Drive gently for about 10 minutes so the engine AND transmission are up to temp. Then treat it however you want. Drive gently again for the last 3 minutes of a trip, and then you only need to let it idle while you grab your wallet and phone and undo your belt. No need for 5 minute turbo timers or any of that shit, although my alarm came with one and I leave it to idle for 90 seconds if i have hit boost near my destination. Follow the above and you'll be rewarded with an awesome car.
https://www.sau.com.au/forums/topic/329372-r33-gtst/#findComment-5352650
Nah, well at least mine didn't, Probably best to get one installed quick smart. I am getting the Auto Watch 446 Prem installed in mine adds Central locking, Immobilizer, Super Sonic etc
Here is the specific features:
Early warning
Remote controlled illumination when disarming for personal safety and to assist in locating your vehicle & selective unlocking
Lock and unlock with ignition window closure
Remote panic
Movement sensor isolation PIN override
Two remotes supplied
Auto-arming three circuit immobilisation
Eight remotes can be programmed in or deleted
digital battery backup siren supplied
2 stage shock sensor supplied
Ignition hotwire
Anti-theft/carpet switch & visual and audible on/off indication
Variety of movement sensors available
Rapid test mode for installers
Alarm trigger report back
Trunk release/second channel output
Turbo run-on
Silent arm/disarm accessible from the remote
Courtesy light fade on and off
Full auto arming alarm with optional locking
Tracking output
https://www.sau.com.au/forums/topic/329372-r33-gtst/#findComment-5352658
The whole advice about don't accelerate around corners is probably the best advice you could get. I did it once nearly crashed into a light pole :rofl:
But i am gonna do both Skid pan and defensive driving
https://www.sau.com.au/forums/topic/329372-r33-gtst/#findComment-5352663
as kinks said, just drive it gently until it has warmed up. no need to sit there idling it for 5 mins before driving off.
run 98 octane fuel
if it is anywhere near to 100,000kms get the timing belt changed if it hasn't been done
never trust how many kms are on the odometer, there's a good chance it's been changed
don't run an atmo bov
change the oil and filter every 5000kms, and use either full synthetic or semi synthetic oil.
https://www.sau.com.au/forums/topic/329372-r33-gtst/#findComment-5353384
Thanks for all the help,
And yes Kinks, i just witnessed my mate slide off a bank into three trees yesterday in his Alfa 33, because he accelerated mid corner, car is totaled and he is lucky he or anyone else wasn't hurt. I was behind him in my MX6, very scary. I do enjoy to occasionally boost, but i wouldnt put my self in a situation where i was risking running such a beautiful car (R33) off the road :P And im very keen to take an advanced driving course, as soon as i can afford it lol
Oh and its a Type-M, i googled for ages and could not find any difference between a Type-M and a non Type-M, is there any difference at all?
Cheers guys
https://www.sau.com.au/forums/topic/329372-r33-gtst/#findComment-5354538
I understand what you're saying here, but on a standard skyline the nose will push wide first, ie they are still set up to understeer first assuming you dont put the boot into it.
Dont put the boot into when you're cornering :D
https://www.sau.com.au/forums/topic/329372-r33-gtst/#findComment-5354894
And yes Kinks, i just witnessed my mate slide off a bank into three trees yesterday in his Alfa 33, because he accelerated mid corner, car is totaled and he is lucky he or anyone else wasn't hurt. I was behind him in my MX6, very scary. I do enjoy to occasionally boost, but i wouldnt put my self in a situation where i was risking running such a beautiful car (R33) off the road :) And im very keen to take an advanced driving course, as soon as i can afford it lol
Cheers guys
in the r33's there isn't really any gts-t's that aren't type m (well there is 1 which is an auto sedan which is a type g or something like that). in the 32's the type m was a gts-t with bigger brakes and leather gear boot or something like that.
https://www.sau.com.au/forums/topic/329372-r33-gtst/#findComment-5355891
The whole advice about don't accelerate around corners is probably the best advice you could get. I did it once nearly crashed into a light pole :(
You are not alone my friend,,
Except i wouldnt call what i did accelerating, i just flooded it and thought id hold on, worked for a little while was like yeeeeehaaaa!!!..till i run out of bitumen and found grass then it was like Wooooaahhhh!!!,Luckily it bit in before the guard rail but left me with a nice little scuff mark so i would never forget to treat her with restecp or she will bite....(Or find wider bits of road :bunny: )
https://www.sau.com.au/forums/topic/329372-r33-gtst/#findComment-5356658
nice avatar arthur!
Shit sorry dude i didnt notice, I know you've had it for a while but didnt realize it was arthur dunger..I will revert to my old avatar again... :thumbsup:
Driving a FWD, ive learnt not to accelerate mid corner, those bastards understeer like nothing else, and once they go theres now way to get it back :ph34r:
FWDs can be good sometimes if you accidently throw it into a slide, it is easy to accelerate out of it, cause the car will pull forward in the direction you choose unlike a RWD that will slide out harder when you accelerate..4WD you get the best of both worlds..But there lack of slidability kinda kills the thrill..
https://www.sau.com.au/forums/topic/329372-r33-gtst/#findComment-5357325
    • I know this is an old thread but I have a particular attachment to the ENR34, so I don't think additional content hurts. For starters, I agree with everyone here in that the performance of a stock R34 GTR is a pretty low bar and one that you're going to spend a lot of money "matching". Now if you're willing to deviate from that template as your goal, you'll be much better off and enjoy the car much more. The engine in the NA R34s is a real kick in the nuts in terms of upgradability compared to previous generation NA cars. The NA heads on the RB2X NEOs have MUCH smaller intake port cross sections and are not compatible with any of the aftermarket forward-facing manifolds available for the RB25DET. This can be remedied with a RB25DET NEO head, but those are expensive relative to what they are. A full long-block from a turbo AWD Stagea is generally a better value and will run you about $4000 USD to get it to you. This will get you the stronger RB26DETT rods, as well. That would give you a base to build off of to be safe in the 400whp range. Not shooting for the moon, but if the stock R34 was your bar, this engine would buy you enough to be just North of stock GTR power. A forward facing manifold would allow for the easiest method toward using Bosch EV14 format injectors such as those from Injector Dynamics and FIC, to name a couple. People hate them because they're copies, but Greddy fakes can be had for around $300 USD. With what the fuel rail, regulator, injectors, and the rail adds, figure $2000 USD for the whole setup including the manifold. With the OEM brackets and a bit of trimming to the ends of the lower frame rails, the OEM intercooler mounting brackets can be used to mount an OEM GTR intercooler, or an aftermarket one made for a GTR. Those are handy vs a universale due to the angles that the end tanks have on them. Then your plumbing become super straightforward at that point despite having to cut a hole where the battery is an a matching one on the other side for the pipes. Battery can go to the trunk. I'd round up to a healthy $2000 USD here too (maybe even a tiny more) to allow for a nice aftermarket unit and some pipe fabrication. Or if you can find someone that's upgrading to something larger, the used market comes in clutch here for a decent savings. I won't even get into turbo sizing as that's something that would be for yourself to determine. HOWEVER, for the purposes of your stated goals, a Borg Warner 7064 with an internal wastegate would be a perfect spooler and would make stock GTR power easily. It would also bolt up to your OEM manifold (that would come with the DET you purchased a couple steps above) if it were ordered with a T3 flange. More with adequate fuel. If you can stick with the OEM exhaust manifold then expect to be in the whole about $6000 USD for decent turbo like the one suggested, a down pipe, new O2, and full exhaust to mate up, and upgrades to the integrated BOV in an EFR or a standalone BOV for a different turbo, as well as an aftermarket IWG (internal waste gate). Those last two are definitely optional and unnecessary. All of this stuff above does you no good without any way of tuning and or monitoring the engine. Bite the bullet on a standalone engine management solution. If your experience with wiring is limited, you're going to have to hand it off to someone else, though. Unfortunately, the adapter/patch harnesses available are typically made around the GTT which does not include AWD, and the GTR, which integrates into a lot of chassis features that aren't present in your wiring interface. So the ENR34 is the oddball. So you'll want to expand a bit on your selection and find an ECU that's capable of running the ATTESA pump also. I have a Link Thunder, but you don't need quite that much ECU to accommodate that. You WILL need someone with the know-how to tune it and code those features into whatever software it uses. And to wire it up. This will be your most significant expense. Call it $6000 USD with an ECU, an okay wiring job (no motorsport grade at this price), aftermarket triggers and R35 coils, and the time it takes to tune the ECU with added features (electronic boost control solenoid, MAP, IAT, the new triggers, and ATTESA) and don't be surprised if it's more if you want better work done. Grab a clutch made for any RB pull transmission R32/R33GTR made for the power handling capacity you're looking for. Budget $1500 USD for a new good one. That's about $20,000 USD for an engine you've upgraded yourself and had wired and tuned by someone else. That's no brakes (ENR34 brakes are pathetic), suspension (again, pathetic), or wheels and tires. So you're pretty spot on in terms of spending $30,000 USD extra on the car just to get it to perform a little better than a stock R34 GTR while looking like a bone stock ENR34 with some wheels and suspension mods. That doesn't include fluids, maintenance items, gaskets/seals, repairs needed or anything else discovered along the way. But you'll have a car you can take to the track and have fun without worrying as much about nicks and dings.
    • Okay so, please read this. car started and ran fine. got my tuned ecu by RSenthalpy, did a bunch of pulls to test it out and finally drive the car after half a year of it just sitting and idling at most. Everything was good, thing ran flawlessly and had so much power, didn't feel slower than a Prius anymore. Parked it back and turned it off.  Next day, I install an AFR and start the car. Didn't wire anything to the ecu. Just gauge.  Car started, but died out in about a minute. I figured it was cause my car was on a lift and the fuel was really low and old. I add 5 gallons of fuel, still cranks but no start. I remove all AFR wiring (tapped into double din acc and power wires but there was a nest of wiring there so I was worried I messed something up. tried to put it back to how it was prior to afr install.) Still cranks no start. Changed spark plugs with brand new ones Changed fuel pump with a new one (verified working) Did compression test , compression came back all at 150ish. All fuses are good, Relay seemed good but ill double check by switching similar relays around. Verified MAF is working - Ended up getting curious as to why fuel pump is not priming when ignition is on, so I cut the fuel pump ground and power and connected them directly to a portable jumper. I also disconnected fuel line to fuel rail to verify fuel is being sent. So with direct jumper power, the fuel pump turns on and shot gas everywhere through the fuel pipe that I had disconnected, so ny doing that, I verified no clogs in fuel lines or filter. - Tried starting the car with that jumper directly wired to power and ground, but car still did not start. I'm guessing its a CAS issue but im a little scared to check it without messing up timing or anything else since I actually dont understand how to check CAS lol. If anyone has any other suggestions or recommendations , please let me know.
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
