marc.. go to msy.. all you need is a standard 2.5" HDD.. they stock 500GB for around 80$ i think.. they have a website
www.msy.com.au
then just d/l the firmware for the ps3 and install off USB.. done..
https://www.sau.com.au/forums/topic/329375-upgraded-ps3/#findComment-5354102
www.msy.com.au
+1
Personally I got the 120gb model and i've no where near filled it up with stuff, I just stream it all from my PC over the network.
By the way you guys having the same avatar makes skimming through these posts difficult i'm looking at you Marc :D
https://www.sau.com.au/forums/topic/329375-upgraded-ps3/#findComment-5354114
yeah i looked on there. a mate of mine always links me to stuff on umart, so i asked him for the site (couldn't remember it). similar price on there as to on msy.
since i'm not getting one till gt5 comes out, i'm just going to see what bundles are around at the time. i have seen some good priced play tv + remote + console bundles around lately and if it is the cheapest way to go then i will get that. but it just depends on whether they bundle gt5 with a console and what price it is.
https://www.sau.com.au/forums/topic/329375-upgraded-ps3/#findComment-5355794
I have a 40GB phat PS3 that I upgraded to 320GB a couple of years ago. Was a much needed upgrade since I treat the PS3 as a media centre.
Best thing about it is that they designed the PS3 to be easily upgraded by just about anyone with half a brain.
https://www.sau.com.au/forums/topic/329375-upgraded-ps3/#findComment-5358598
i've got the original 60gb console and its epic i love being able to still play gt4 along with all the other extras it had.
i run a media server from my pc anyway so i use bugger all ps3 hdd space, still using the original drive. love it.
https://www.sau.com.au/forums/topic/329375-upgraded-ps3/#findComment-5362793
  • 3 weeks later...
    • Yeah this was also my suspicion, that pineapples exist to reinforce the OEM bushes because people CBF taking the subframe out to do it. Basically that pineapples and subframe lock collars perform the same intended task. The cup still bolts in under the bush/crush tube.. as to how it'll go I don't know. Two of the bushes at the back look mostly the right shape. The ones up front clearly have the impressions left by the pineapples. Time will tell whether this will work/make any difference. Ideally I would not want any lock collars or pineapples, I'd just want the bush to do the job of the bush. Time will tell if the car works correctly with only the poly bushes in the state they're in. Worth seeing, I think.  What panel work are you looking at? I'm shelving everything from the A pillar forward because it's shit/doesn't function and this was before I drove off at the track and then drove into somebody! A second hand Reo and brackets is $1000, which is just cray when Mr.Hammer turns this piece of metal in regular metal shape.. considering it needs to be drilled to be adapted to the GTR headlight brackets anyway... So I'm all for $0 instead of $2000 (new 34 GTR reo) for the same result lol.
    • I think he's already demonstrated that that's the way he's treating it post the paint jail release.
    • Yep that makes sense, thanks! I guess flogging these turbos in winter is more preferrable lol.
    • Bahahaha, bloody hell Greg. You've got bent and broken things, but instead, you're replacing perfectly good items. This story keeps getting more gregged!   Also, I'd 100% replace that reo if I were in your shoes, unless you panel beater is REALLY good. Even if you put another GTT one on there. Just because you've done so much nice body work lately, I'd say repair the body work fully  If it were more drift car spec, I'd be all "Hit it with a hammer and send it!"
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
