120,000k's
Silver
Airbag
Hks 2540 turbo (Hiflowed)
Apexi hybrid intercooler
Hks Air Pod in custom box
Z32 300zx AFM
Big aftermarket fuel pump
Nismo 555cc injectors
Apexi fuel regulator
Nismo oil, radiator and fuel caps
Strut brace / stabilers in engine bay
Custom 3 1/2 inch exhuast system with twin inlet to muffler
OS Giken Triple Plate Clutch
Tanable Adjustable Suspension
Apexi Superbrake cross drilled and slotted rotors all round
EBC brake pads
Tint-a-car Formula 1 window tint
17inch crome Equip Work Wheelswith rears deep dished
Dunlop 235's on front and 255's on back
Nismo clear indicators
Nismo Carbon Fibre door pillars
Apexi 60mm electrical guages x2 with controller unit (boost and water temp with white face) on greddy pillar
Apexi 60mm Power in HP gauge with control unit with white face
Greddy 52mm fuel pressure gauge with white face
Nismo 320km/h 11000rpm complete dash cluster, white face
Hks turbo timer
C's Quick Shifter
Nismo aluminium gear knob
Custom gear boot and handbrake boot
Apexi Power FC with hand controller
Momo racing foot pedals
Custom glove box setup with AVC-R boost controller
Apexi RSM with g-sensor
Nismo crome key
Top of line Brantt alarm system with Viper remote pager with digital display and 1km range
Alpine CDA7893R Bass Engine MP3/CD Player Headunit
Apline Type R SPR-176A 6 1/2inch splits
Serviced every 5000k's
Approx 230rwkw
Only problem is clutch is on it way out will cost $1000 to rebuild the triple plate clutch
MUST SELL ASAP
Contact at 0423 351 754
https://www.sau.com.au/forums/topic/32939-modified-1995-skyline-for-sale/
  • 1 month later...
  • 3 weeks later...
Umm, I am interested. But for someone who doesn't know much about cars. On paper a triple plate clutch is like 2700 to replace.Rebuild it maybe 1200ish. plus labor. There is a similar R33 in the trading post for 22500 230rwkw.How much rego is left and are u prepared to get a RWC???. Before I will talk price seriously I and many oters would like these questions answered. thanks.
im selling the car at $21,000 which is really cheap for a car like mine as u can see in the pics alot of money has been spent. i need to sell the car and need to asap so thats why im willing to drop the price to 21,000. The car will be sold without a RWC as i dont think its possible to get one with a slipping. I was quoted $1000-1100 to fully rebuild the clutch and fitted with labor. At this price the car will not come with the plates either
120,000k's
Silver
Airbag
Z32 300zx AFM
EBC brake pads
Hks turbo timer
C's Quick Shifter
Nismo crome key
Approx 230rwkw
MUST SELL ASAP
Hi,
I'm about to buy the above clutch kit, reading your post your car does 230 KWRW with the great mods. I have achieve 210KWRW with standard turbo and internal engine. Could you advise me is it worth using the triple plate, and it's there problem that lead to such as:-
- Have to rev up to certain RPM for it's to move
- Much heavier then Heavy duty clutch
- Rattle when dis-engaged
Or better off getting twin plate clutch
Thanks,
Jack
the triple plate is cool to have
but can be a bit of a headache sometimes
takes alot of time to get used to, but havent tried a twin plate so wouldnt know the difference
Hi,
Thanks,
Jack
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
