I have some stuff to clear out in way for my next project.
Ported GTR head. Head has been mild ported, mainly to clean and de dag as well as smooth the ports. The valve bowls have also had a tickle to ensure a smooth laminar flow.
Comes with standard cams, cam gears, cam cover, rocker covers, valves, solid shifters and shims.
Missing, Most cam caps(just get a set of rb20ones and line bore it) cam cover backing plate, valley cover and CAS.
$1000
GTR injector plate/inlet manifold(not plenum)
Has been cleaned and ready to go.
$300 hard to get...
Performance Valve springs.
Brand new, never used. Can use up to 10.5mm lift cams and higher rpm.
$200
CAS/dizzy
A rb30 dizzy has been welded on to the cas.
My intention was to use methanol and as such use a MSD ignition system to create a fat spark. It was easier to do it this way than individual coil setup.
Still uses standard rb25/26 CAS internals and wiring plug
$250
Billet 14mm ally fuel rail
Has 2 outside 1" bsp inlets and a central 1"bsp outlet.
It has been die ground on the bottom of the rail to clear a manifold. Never actually been used, only to fit up injectors and manifold.
$150
Tomei red adj cam gears. Old style. Used on my rb25/30 setup. still ok
both $80
I just haven't taken pics yet, but will do so on monday
Please PM me or call
0412957329
Thanks.
Pics added
Also for sale is a Brand New set of SPOOL RODS for RB30.
Never been taken out of the packet, only for the purpose of the pics.
$680
Genuine NISSAN VRS gasket kit for RB30/25.
Has everything for rb25 head onto a 30 block, so rb30 head gasket. Inc rb25/26 on 30 cam belt, though it is used.
$200
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
