Ok I need the SAU guru's to help out on this one.
My car is an R33 gts-t with very low milage in good condition. The following mods/work have been carried out:
- Std Turbo with std boost (5/7 as confirmed by a boost gauge)
- R34 gt-t intercooler (cleaned out)
- 3inch bellmouth dump pipe
- high flow cat (apparently xforce, came with car)
- 3inch stainless system with two big mufflers (also came with car)
- new timing belt (timing reset)
- full fluid service (inc. AFM clean)
- new iridium ngk standard spec plugs (5 heat range, 1.1 gap)
Now the cars runs really well, really stong.
The car has developed the typical br25 flat spot on some nights (keep in mind it is extreamly cold in melbourne at the moment)
The car takes off hard, then flatens out, then feels strong again. This matches up with what I have searched in relation to two things. Not there is no obvious missfire (ie spluttering, coughing)
1. R&R
2. Coils/plugs
Now R&R seems unlikely given the car is running std boost? Is it possible to get R&R is the air is cold/dense enough?
Second I took the coil cover off in the dark and the not one missfire is obvious at any RPM. The car only has 80,000ks and is in exception cond so its not impossible that the coils are ok, Cant find any cracks...
So im confused??? Is it my heat range 5, 1.1 mm gap plugs? Is it R&R?
I must have read 50 threads on the topic but everytime R&R appears is on higher boost and the coils show missfires and actually missfire (ie splutte where mine dosnt?)
Thoughts? :rofl:
im not the smartest of the bunch but just throwing ideas out, i havent read up on this problem either. lol.
maybe try putting it on a dyno? do a self diagnostics on the computer to see if it results come up with anything, i have read somewhere that a TPS can cause this?
get a proper boost guage, with free-flowing exhaust and cooler intake (weather) your boost would be more like 10psi
Id suggest a SAFC to fix the issue, setup correctly on a dyno
well I took it for a drive today, being slightly warmer compared to at night and perfect. pulls strong all the way through. Slight dip at around 4500 but some have told me thats to do with the VVT? is that the case?
Was worried about my spark plugs too, heat range 5, gap 1.1 but given im only running the standard boost I think they should be ok?
PS still only getting 7psi on the gauge (digital) with these mods
RB25 Doesnt have VVT, it has VCT and the default kick off is at 4700rpm
it comes on early in the RPM range and off at 4700rpm
if VCT was dead/disabled your car would be sluggish always until 4700rpm
when it feels flat does the RPM tacho slip to a higher rev range? aka clutch slip
when you light cruise do you notice any different behaviour? aka 02 sensor
thanks for the replies.
Ok would you be able to feel the vct change at 4700? definately no 'flick' of the tacho indicating broad minded personch slip, it is all very smooth, no pops, crrackles or anything odd. Just that 'flat spot'
No problems in cruise. Not I have also replaced the O2 sensor as part of my service and cleaned out the AAC valve.
I have considered the plugs, coils do seem fine and 9 times out of 10 there is not an issue. Didnt want to bring the gap down from 1.1 if I didnt have to but might be required
how cold it very cold?
do you have a real boost gauge ? or the factory waste of space on the dash that happens to resemble a boost gauge?
its gonna make the ecu see more air/denser charge and send it into slack timing look at this picture and youll see what and why .
it runs something around 20-17 then chops it back to like 6 then back up to 14 ish
interesting graph, that certainly wouldnt be helping, wonder why they were so aggressive at that rpm range?
I think its relatively normal on the stock ECU with the mods you have.
This is mine:
Before, and after an SAFC2 tune. Managed to improve the dip as you can see. But its impossible to eliminate without timing adjustments!
And, just so all you "veteran" SAU posters dont get excited, hub dyno, different country.. so dont fret about the "happy numbers" The peak isnt what i was looking at in this instance. More the gain and improvements. :happy:
1. R&R
2. Coils/plugs
Thoughts? :happy:
i had a similar issue, im in hamilton, NZ and we get thick as fog and the temps have gotten down to -4 deg a couple of times so far this winter. my car also has similar mods to you and my car has done around 82000ks. i recently changed my plugs to bcpr6es (i think) with .8mm gap. and it mostly got rid of the problem, so i suspect it could be a combination of plugs and coils (even though my coils look fine). so i am looking at getting some new coils soon. i run high boost all the time, and its around 9psi because of the mods. im suprised that your car still sits an 7psi at full noise, and my exhaust is the factory one with the mid muffler and cat removed.
Edited by R3N3
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
