Yellow Sticker, Rwc, And $300 Fine. (not A Rant)
  • Replies 61
They dont care how many things are wrong of whatever they give whatever they want, Ive been majored and given a fine for just having a pod and cooler and other times for just being to low.
While we're hear, is that your girlfriend in your avatar?
haha, i too would love to know :D
lol, I thought something like that would come up sooner or later. Yay for random babes in avatars! :D
Leigh is was on high st. at high st shops.. remember last time he got me in november. i was washing my car at the caltex car wash on high st. he did laps past then eventually pulled in parked next to cleaning booth and waited almost 30 minutes for me to drive out with him standing infront of booth pointing to park i was liek FFUUUUUU. too bad he didnt find a turbo after ripping my centre console out to look for a boost controller in my NA.. at the time
yeah bad luck i got done too (FU eastside) and they got me for too low. Only at back of exhaust which had recent repair of altercation with winton cliff face. I too got $300 a minor and no rwc.
The epa is a coming....LOL :P
lets hope someone snaps at this fool one day
I can understand if he gets you legitly but to grill people and fine/defect them over nothing, he has a problem.
wouldn't be surprised if he smokes bernie rankins pole daily.
That is because it is at officer's discretion to issue a notice of unroadworthiness along with the defects. I have received defect notices without NOU before. It's just another thing they can add to the pile of paperwork for you to clear up depending on their mood on the day I guess...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
