R33 S2 Rear Seat, Kakimoto Hyper N1+ Rev 3.5' Exhaust For R33 Gtst & Gtr [syd]
Mint. Good to see another GTSt getting love and coming back to life. Did I miss what colour you are going to wrap it?
So far, based on the maps. Looks like 42 frame size 68mm & 72mm And 45 frame size with 67mm and 73mm
Another complicated thing is to run Z32 alloy hubs which have wheel speed sensors for ABS. You need different tie rod end, and you need new bearings on the upright etc. I did that as part of a major refresh when my front kingpin bearing flogged out., Alloy was a little lighter, runs a bigger bearing , gives a few extra mm in wheelbase as it moves the wheel forward in the arch (cant run crazy but can still get 8ish comfortably). All in all glad I did it but was a head fark as tried it once and abandoned it the first time. sav man swung his spanners at it and got it working so using his guidance on GTR/Z32 tie rod ends etc and the required mismatch of parts was able to make it work. Probably a 2k upgrade all said and done :( I think the best bet is just look around your front wheel and see what you can pick up rotationally. You see old Escorts, E30s etc all get very creative with front uprights and the humble old angled alloy bracket.
