Thought I would share the progress of my 32 GTST I purchased March last year
this is what it looked like on day 1 of ownership. Stock as a rock apart from a FMIC
and then gave it a good cut and polish
First week I had the car I went to town on it on ordering some new things to make it reliable
all hose clamps for water, fluid and fuel hoses
all water hoses
all pwr steering fluid hoses
all fuel hoses
rocker cover seals
040 fuel pump
removal of hicus crap
putting a full brg set through the gearbox
cleaned everything up
found a cactus brg on the mainshaft in my gearbox which is a common cause for skyline rollover noise
So once that was all done I purchased some 32R rims
gave the GT badges a polish
http://i19.photobucket.com/albums/b182/20v...03052009002.jpg
installed a 3" bellmouth dump pipe and 45V1 R33 Turbo
then replaced a the front end bushes and installed some new K sport coilovers
which lowered it somewhat
engine bay is now all clean as well as the air con system at the front of the car
next bit was to put in a new 3" mandrel bend system
and then a nistune done by sean at allstar garage
stripped out my boot
then I got real, pissed off the 32R rims and went for some buddy clubs
more to come!
https://www.sau.com.au/forums/topic/329420-r32-gtst-project/
then it was time for a new windscreen and front and rear rubbers
then put in new gearboots
then one of these under the dash
new bigger battery and clamps
new pads (ebc redstuff) which I have not fitted yet
dba 4000 slotted rear rotors
and I have these on order (324mm gtr front upgrade on 4000 dba rotors)
also not mentioned yet is I put in a rear 32R sway bar and RB20 diff from an auto for the shorter ratio
see if I can work this out
Rims & Tyres -$1100
Brakes - $1500
Fuel Pump - $240
ksport Coilovers and nolathane bushes $1900
nistune - $950
Gearbox rebuilt $500
Gearboots $30 odd
bee*R $300
Mandrel steel Exhaust $450
Seals, Hoses, clamps ect.. about $400 from memory
Turbo $300
Dump pipe $200
GTR rear Sway bar $20 (CHEAP CHEAP)
Rear auto diff $150
Strut brace for the rear $80
Tint $60 and seals $50 (mate of mine does windscreens & tint ect)
Dry ice sound deadner removal was about $150.. Dry ice isnt cheap!
Thats as much as I can think of, All the new stuff is below trade price too.. glad I didnt pay retail for any of it
duno if I wana add all that up LOL, would be almost 9K i rekn
im building a 25 for it next year, still pretty keen to spend more money.
Edited by BANGN
f**king gorgeous .... wish mine would look like this ... ( the Bee*R rev limiter) what do u use it for? ive seen them applied (ignition cut) with all the backfire which is awesome but .. what are they used for? launching?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
