  • Replies 41
no....Apart from the flowed head i am getting i do everything myself...right down to the block boring....so the money you guys pay other people on doing stuff...i get to spend on the parts...i would be interested to see how much work some other people do themselves....i find it interesting to learn about stuff from actually doing it yourself apart from just paying someone or reading on the internet....My mind is a like a dry sponge!I look for stuff to absorb and hope other people can also learn from the things i have learnt...this is why i aint usually at any functions or partys ect...i can always be found in a workshop or machine shop somewhere......usually playing with something out of the ordinary!
I would love to do that also but if i spent time doing that i wouldnt have $$ to do it coz i wouldnt be at work. Catch 22
you needs lots of time to DIY but the results are worth it..
my goal is one day to pull out an RB engine and put it back together :D I've done it for the rest of the car so don't see how the engine can be that more complicated :D Its all nuts and bolts afterall, not rocket science..
Good work anyhow.. learning to do it yourself is the best thing about owning one of these stupid-ass cars :P
Y u going for hardcore internals and then only twin 2530's???
Y not twin 3037's and make those internals earn their keep :P
INASNT: Maybe troy is going for something more responsive and rather than outright power!!!! Do I see a Mine's GTR in the making????
I am after a good strong reliable engine...thats why i used those internals....the car gets cornered really hard (twisty fun stuff....not so high speed)thats why i am thinking dry sump...I learn my stuff from trial and error ....some books and the internet can be way off but also some people i know also have knowledge that i have gained access to and learnt off...and you would be suprised on who these people are.....a peice of one persons mind and a peice of another and put it together and you got a good bit of info...however storing it can be a problem sometimes ;)however some people dont know about a certain thing you ask them and they guess but not telling you they guess and more often than not...they are so far wrong its not funny!This is done sometimes due to people being embarrest to admit they dont know (and some of the time they are from popular workshops!)I have alot of respect for very intelligent people that say "jeeze i really dont know about that" Bottom line is we ALL learn new things everyday but unfortunatly some people dont want to share them....some of us do....i dont know that much but what i do know i am willing to share!I enjoy motivating people hence my posts/pics...they are not to show off or anything else...i hope they are welcomed!I learned a hell of a lot from the builder of this unique engine...sorry for the speach :P
yeah a few cars have em now, they sold like hotcakes in japan when they came out. Din know they were Trust tho.
BTW troy u still lurking around in Brooklyn? might come by n say hi.
ur a wise man troy and i always enjoy reading ur posts with the stuff ur doing and like u say learning stuff (and to drool :))... i hope when its all done i can see it all in the flesh :D
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
