stagea one is better. no cooler or should i say warmer... ideal for a relocator conversion. but the new ones are all aluminuim. early ones (one of a motor) has a steel thread.
or if you want a rb20 one is better again. but straight out of the block, not angled. new ones have a steel thread. but you have to use a toyota filter (z418) or any with a relief valve in it)
I have several laying around my shed you can have one for free if you are going to use one. They are pretty useless and you would be better off with a relocation kit and aftermarket oil cooler but as i said if you do want to use a factory one you can have one for free just pay the freight or if you are on the gold coast or brissy area just pm me and you can pick one up.
jJust to clarify when you guys say to get rid of it and fit a relocator and external cooler dont they replace just the filter and is there a housing off a different rb that still has both the pressure and temp fittings? I there any kind of aftermarket cooler that replaces just the heat exchanger part and leaves all the other bits exactly the same? Obviously you would have to jump the coolant line back into itself.
what about (factory oil coolers) my 1993 gtr has an oild cooler mounted in the front passenger side vent... is this a factory setup??
i was wondering about it???
cheers
Not factory, the factory oil cooler (oil/water heat exchanger is a more accurate description of it's function) is as what the the picture suggests, attached to the block.
Oil cooler kits found on the passenger side behind the front bumper are aftermarket ones.
The oil cooler shown above is as much an oil warmer as anything. It does very little to keep the oil cool. It is not uncommon for the part to fail also.
So the question is - is there an aftermarket part that replaces the oil cooler bracket in the diagram at the top and removes the oil cooler/warmer as fitted by Nissan?
Yeah i hear ya,
but what i mean is, alot of the Nismo equipment is offered on a new purchase.. so essentially its a"factory"option. Note the quotations.
And i dont believe there is a bolt on replacement for the factory oil warmer/cooler.
The RB20 doesn't have the factory oil warmer, so the taking the mount from it (housing, bracket? im not sure what the name of it is) is popular when you have an A/M oil cooler.
$120 fron nissan for a rb20 one.
unbolt your oil cooler/filter housing and bolt the 20 one in its place. use a z418 filter, not the genuine nissan 145 as you no longer have a relief valve.
(rb20 has it on the block, where as rb25/26 has that part blocked off and instead has them in the oil cooler/filter housing)
if you are using a remote filter, put the oil pressure sensor in it there, and lengthen the wiring to it. if not then use the 1/8 npt port to the rear of where the filter/cooler housing bolts on to the engine. (at about cylinder 5 along the block)
nismo has a replacement housing, but its like $1000. it has 2 -12an fittings where the cooler sits.
also nismo has a oil cooler kit, said housing, with a custom aircon condensor with a 25 row oil cooler integrated into it. i have one in my garage. i had the brocher for it but i lost it. was an option for the aussie deliverd ones.
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
