  • Replies 50
My understanding is that the atessa sends 5% drive to the front wheels as a minimum at at all times.
Regarding fluids when my car was auto I bought 20L of quality synthetic atf and used it in the auto, the atessa and the power steering.
Well just as abit of of an update with my car, took it to a GTR doctor xD, got all the fluids in the car changed, $600+ of fluids! Both diffs, transfer case, gearbox, ATTESA actuator.. everything done except a coolant flush which is getting done next time i'm there.
My mechanic belives that it is most likely a G sensor. However upon driving he believes that there is something abit wrong with the speedo.. When accelerating it stays on 0kph then quickly rises to say 40kph, the delay is minimal however he belives that this could also cause my issue. As the ATTESA takes inputs from the G sensors, speedo etc right? So if there is a delay, the ATTESSA might be tricked into believeing there is wheelspin.
Any chance of this being the cause? I plan to get it looked at again in the near future!
Looking at the R32 RB26DETT System Figure, the ECCS unit gets its' vehicle speed signal from the speedo which gets it from the gearbox.
I can't find a diagram for the R32 ABS/ETS unit but I would imagine that the system is only looking at differential readings from the ABS sensors.. will have a look when I get home.
Edited by bubba
Yeah it looks like the ECU gets the vehicle speed from the speedo (for speed limiter etc) but it also looks like the ECU only supplies the ETS (attessa) with throttle signal and engine RPM, I guess the ABS sensors would be providing the speed for the ETS computer. If you end up needing another speedo with speed sensor let me know, i've a spare.
Roger that doo doo!
Is it possible to repair the speedo without changing the cluster.. as i believe my car has genuine k's and would like to keep the "standard" ODO on there if possible.
If it is something as simple as this to fix my problem that would be a massive relief!
I had pulsing issue where if the car was cruising around 100km, I could feel the car surging forward slightly every 5 secs or so constantly
at the time if didnt put 2 n 2 together as I was only fixing the flicking needle but it also sorted out the surge as well
Hm my issue occurs at 100kph as well, not sure if mine "surges" .. the torque just goes foward after a certain amount of time.
I will have to get this fixed asap and see if it solves my problem:D
The 'speed warning' unit which looks like a fuse is interchangeable between speedos so you can keep your original cluster. Still don't know if it supplies speed info for ECU or if it's just a limiter warning or power steering/hicas input. If it's jiggered it might be doing something funny to your attessa at 100kph, but check the speedo cable first. After the G sensor of course
are you 100% sure the tyres are all the same???
do a liltle test, put the tyres on the front on the back and back on the front, than go for a drive and see if it is the same.... if it dose than its a prob with the 4wd system, theres a test you can also do its in the workshop manaul mite be worth alook
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
