yea common problem, over time they get a build up of crap in and around the nozzle. not sure if theres any sure-fire way to clean them out properly cos they dont come apart. but the usual way is to get a fine tip needle and poke it around inside the nozzle and clear away what you can, then put compressed air through it. failing that, im sure new ones wouldn't set you back much
https://www.sau.com.au/forums/topic/329538-washer-nozzles/#findComment-5355951
  • 3 years later...
