Hi everyone,
I need to install neo rb25det intake manifold to non-neo rb25 engine.
The problem is that intake ports are different despite the same gasket. On the photo you can see rb25det neo manifold on the right and rb25 non-neo head on the left. The difference is in the injector section -- it is much smaller on the neo manifold.
I know that installing greddy front-mount manifolds is a usual thing for many of you -- so the question is -- do you grind intake ports on the neo head to match greddy manifolds (which are designed for r33 heads) or just install it with this port mismatch?
  • 1 month later...
ok, i`ve found the neo head and the head intake port design is exactly the same as in the non-neo head. That means that the port mismatch (as seen on the picture) between the neo head port and the neo intake manifold is designed by nissan for some reason -- maybe for extra turbulence right after the injector for better a/f mixture.
thanks, thread closed.
