bov opening at full throttle... relesing all pressure in a slit second will cause the turbo to spin way more than what its ment to...
mines failed at 14 aswell... i cant c this 'compressing the housing mod" being at all legit!
Edited by chef_stagea
Not saying your bov is faulty but there is a mod suggested by a tuner. Take the bov off and you'll see a small hole about 1.5mm. Ideal: find a threaded screw or bolt and tap the hole to suit. Put the screw in and mark where it sticks out. take it out and cut it off there and cut a slot in it and screw it back in. Not so good: get a self tapping screw and do the same.
I ended up getting a GTR bov. It bolts up fine but the hose is bigger so you have to adapt the plumb back.
whats the advantage of this?
do the c34 bov's have this? i didn't look last time i had the bov off
It's been debatable for a long time if that does any good. Some say yay, and others nay. But for 30sec worth of effort, it doesn't hurt to do it!
C34's along with all other rb25's have it.
Glad I found this thread. I've been turning up the boost on my series 2 and I think I hit fuel cut. I asked on the regular skyline pages and was told that disabling the boost sensor could be a bad thing because it leans out your AFRs, though I'm running rich (around 10.5) at full boost.
My Stagea has FMIC, Walbro,Iridium 1 grade colder plugs,new coilpacks,Apexi induction kit,decat,80mm cat back exhaust,gizmo ebc and hybrid steel internal turbo.
  • 7 months later...
Reviving an old thread. My S2 has started doing this recently, i noticed my boost had dropped from everyday 10psi to 6psi according to my boost gauge, so i turned up the Turbotech boost controller but when i floored it, engine seemed to cut out at full boost, which still was under 10psi according to the gauge mind you. Never had this problem before even up to 12psi. Is the MBC shagged? or is the boost gauge wrong?
What should I do? Looking at getting Nistune done with the next big service, would that fix it?
Edited by webng
Sounds like a boost/fuel cut to me.... Mine does it to
Yeah that's what it feels like, but why all of a sudden now? Maybe the boost gauge is buggered? Or maybe there is a boost leak somewhere? Whatever the case, i'll be booking in for the Nistune done this week I think.
i know im an M35 owner, but I will be interested if you find a result to fix the issue.
mines doing some sort of airflow cut at 20psi. but the airflow meter is clamped at 4.70v(well before AF Cut)
so i'll be keeping an eye on your result.
Have you checked the vac lines to the boost gauge? Could have a hole in it. It sounds like your hitting the factory ~14psi boost cut the S2's have, if your gauge/lines are faulty and the gauge is displaying a lower reading, then you may have turned the boost up too high and are hitting the limit.
Just a note on the boost dropping off- Why has no one said anything about the turbo can't make 14psi all the way to redline, shit it cant hold 10psi to redline, the VCT is there to fill the hole in the turbos abilities. I've got a turbosmart type 3 and its still loses boost. The boost drop off is because the turbo is too small. I'm pretty sure it's just one more factory floor for the poor old stag. Thanks nissan :(
If it is the boost cut, R and R or suchlike then a tune with a Nistune will fix it.
It just occured to me... would putting 100ron fuel cause R&R?
Cooler weather, might be hitting a tiny bit higher boost.
But never happened with colder weather before.
This sounds possible, will have another look at the lines. Edited by webng
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
