Hi all,
I have a R33 GTS25t with a GT-RS. I'm not sure what the issue is, but the turbo whistle is too loud. It basically sounds like its spooling, but happens at very very gentle throttle angles. Pretty much just off idle it starts, cruising at 110km/h its a constant whistle (i.e. really, really annoying).
Does anyone have any experience with this turbo? My mechanic suggested it was because I used to have a foam filter on which does not block any noise, however I changed it to a K&N item and it's only slightly quieter.
Other things I have pondered include the BOV leaking (its a standard item) and some sort of resonance in the intake piping. The second option doesnt really make sense though as the whistle happens all the way through the rev range. I'm just hoping its not a problem with the actual turbo.
It is getting tuned on Wednesday and that is one of the things my mechanic is checking, just wondering if anyone's been through this already...
https://www.sau.com.au/forums/topic/329559-turbo-whistle/
seriously how can u not like the sound of a turbo spooling!!
yes the standard airbox will shut it up
and i remember SKYRYAN (from perth) in his forsale section a lil while back said he had a gt-rs and said its f**king loud, theres nothing wrong mechaniclly with it, thats just how those turbos are - fkn loud. throw him a pm might be able to help ya out
https://www.sau.com.au/forums/topic/329559-turbo-whistle/#findComment-5354900
pretty sure u got a few grub screws in the front housing that holds the port shrouded cover in place... remove it and ur whistle will disapear..
i was running a gt3076r port shroud and i got over the whistle after a few weeks... only decent whistle is a hks t51r or t04z on 30psi bahah :D
https://www.sau.com.au/forums/topic/329559-turbo-whistle/#findComment-5355058
any amount of opening the throttle will make it whistle away with a pod filter, like a mack truck
go back to the std airbox to shit it up and keep it quiet
Yeah, that might be the go. Pretty keen to keep it looking as stock as possible under the engine bay so that would tie in nicely.
Its a bit anti social.. and plus I don't think the po po would appreciate it. Plus, its reaaaaally annoying on long drives. Acceleration spool is cool, yes. Constant drone, no.
If you get a Buzzz ..z zzz z.zzz sort of bearing noise on vehicle power off. It could be bearing noise. Which means they needs replacing.
Nah no noises like that to report..
Excuse my ignorance, but what is a port shrouded comp cover, what are its benefits and will it do anything if I remove it?
Edited by SoFreshSoClean
https://www.sau.com.au/forums/topic/329559-turbo-whistle/#findComment-5355235
You wuill see on most larger sclae turbo the inlet has little holes or a lip in it. It is there to stop or help reduce compressor surge.
Due to the amount of boost these turbos run it help created a bit of turbulence and the air running over these "holes" is what is creating your whistle.
I am sure there is more to it, but that is my limited knowledge.
https://www.sau.com.au/forums/topic/329559-turbo-whistle/#findComment-5355394
Hi all,
Its just the way GT-RS turbo's are. I have a GT-RS turbo with a APEXi pod filter, and YES it is extremely loud whistling noise. On a long drive it does get annoying, but my exhaust is pretty loud too, so it drowns it out a bit, and i always have my stereo at a decent volume so it does not bother me too much.
Put a stock airbox with snorkel back in and there will be ZERO whistle. But the trade off is you can hardly hear your turbo at all........
At first the whistle was a bit much, but its grown on me nicely. I borrow my mates ute sometimes and he takes my car, and he freaking loves it, even if he does not have to go anywhere he goes for a drive...... so whatever floats your boat i guess.
https://www.sau.com.au/forums/topic/329559-turbo-whistle/#findComment-5355415
Hahaha yeah you dont mind hearing a turbo whine when your giving it some stick, but not when your just cruising on the highway. As said previously, stock airbox will stop the noise.
Other option is to get a bigger turbo that doesnt spool when cruising on the highway :happy:
https://www.sau.com.au/forums/topic/329559-turbo-whistle/#findComment-5355577
I see, thanks for your help
Other option is to get a bigger turbo that doesnt spool when cruising on the highway :)
Yes! You get it.. cruising noises are just irritating. GT-RS was chosen because it has similiar lag to standard.. it passed over the pits but will still flow 400hp :happy:
https://www.sau.com.au/forums/topic/329559-turbo-whistle/#findComment-5355783
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
    • Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes.   United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows)
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
