i got a set of freshly recon'd 550cc purple tops off ebay and just wondering if any one knows much about them. i have heard if your fuel is rich in ethanol it can cause damage. i only every put 98 octane in my car so will this be a problem??? anyone with a set? im hoping that it is just an over exageration
https://www.sau.com.au/forums/topic/329578-nismo-550cc-purple-tops-question/
uploading a pic now to silence all, these will be going on my rb25, he says their high impedance but he tells me had them/or was gonna put them on his gtr but didnt. would these fit no problems with a aftermarket fuel rail
Edited by chrislesnar
What motor is this going on? NEO or R33 RB25?
And no ethanol does not harm injectors. (forgot to answer this earlier) The mythology is, that ethanol corrodes old fuel lines. Realistically this is a non event for most skyline users anyway, really only a variable if you run an E85 setup, and even then there arent THAT many rubber hoses to replace in the car anyway.
What colour is std, I thought purple was std???
Mines a '98 R33 and I've got yellow tops= nismo 555's and they flow like that as well - they were on the car already from Japan, but I'm sure that purple tops were the std colour in '98 rb25's??
Purple is stocko for RB25, but it looks to be a different purple again lol.
If I were you, the risk is too big, why muck around with all that. Snap up a second hand set of nismo 555s or 740s for 700 bucks, plug and play.
They are top feed injectors in the pics. They are definitely not stock RB25DET side feed injectors regardless of the colour.
x2
On another note, I had Denso 550cc injectors in my GTR when I first bought it and I'm pretty sure they were purple!
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
