Any importers or knowledgeable people out there know the average, or just a rough idea of the, price premium a V-spec II has over a basic GTR (34 GTR) when importing, assuming all things equal, say grade 4 stocker and just for shits and giggles perhaps Nur price diff aswell ?
or is it too varied to bother putting a number down ?
https://www.sau.com.au/forums/topic/329582-r34-gtr-v-spec-ii-premium/
Price to import vspec II will most likely yield over 65-80k landed and complied. All depends on condition. In regards to the nur, mine was almost 90k landed and complied 4.5 grade (only cause of the k's). Now I'm not sure if colour has to do with anything fetching higher price but I find that pirvate sales here will be cheaper than importing (the yen is tough) but I reckon importing is for finding a top quality car if you do the research.
I'm sure the import guru's here can give you the best advice. This is just from my experience.
thanks mate. Yeh the reason I'm asking is looking around at private sales a V-spec II is only around the 55-60k mark (obviously there are some more expensive ones out there too) and a plain GTR is around 45-55k so not a HUGE difference, but I was under impression importing a V-spec II would be around the 70k mark so just wanted to clarify :)
thanks again
perfect advice. with the way things are right now with the aud and with the current car market and the japanese market you would only really import a GTR to be able to chose from the largest pool of cars and have a chance at finding a really special or rare car or just one in fantastic condition. but if you want a average condition R34 GTR at a bargain price then you should probably be shopping locally and haggle with local sellers. It holds even more so for R32 and R33 GTRs but still applies to R34s in my eyes.
cheers baron, tbh I would rather a VERY clean stocker than a cheap already modified car. But will look around a bit more and see what the potential difference is.
I want something as close to stock as possible, dont mind intake/exhaust and rims and stuff, but nothing thats really modified, built engine, big turbos or anything like that
Also I'm specifically after a white V-spec II, so I figured importing would have a larger pool to fish from
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
    • Throws on the FS5R30A in most Nissans of this era are actually quite short and direct compared to any remotely modern BMW with the S6-53 transmission. Those things have throws a mile long with rubbery vague everything. Synchro issues combined with a short shifter is just going to break everything even faster.
    • Only thing I'd add...is on recommendation from a good diff shop, I've used mineral oil in my diff including the race car for years. The synthetics can be too slippery and glaze the gears
