GTR to pass EPA - what else to do...
Having gone through a thread populated with comments from Whistla and Pred (thanks boyos) - I think I know what I need to do... but I have a few uncertain bits.
Cat: Perhaps I should get one? - no more flames ;)
Exhaust: According to Fujitsubo - it meets Jasma compliance at 95dB. Is this too close?
ECU: Mr PFC has to come out :D Asked Jack to borrow a stock one.
Pods: HKS twins - caged but not covered. Cop who did defect said they OK. Are they?
FMIC: R33 N1 item - factory option.
Rest of piping is stock.
The queries:
AVCR: Do I have to remove it? Or can I run stock boost and be OK? If I have to remove... how much do I take out?
O2 sensors: Dr Drift suggested these might be stuffed - hence my aircraft carrier style fuel consumption - will they affect the emission test? My thinking says yes...
Thanks in advance for help :D
https://www.sau.com.au/forums/topic/32959-gtr-to-pass-epa-what-else-to-do/
i asked nige about bleed valves and boost gauges being leagal or not. he said technically they arent, because it can wreck the emmisisons of a car, even if its at a stock boost, their is still chance that the user would put higher boost and they dont like that (even if your pfc fixes all the emmissions) and plus the pfc has to come out anyway
im guessing fmic is ok because its standared
with the turbos, as inasnt always says, the cops, vicroads, and epa always have their own rules for some weird reason. best to check with epa about that, but i dont see how the turbos could affect emmissions or whatever? i dunno really
Thanks guys.
Dox: Turbos are stock - so they'll be OK.
Troy: Like they say, sneakiness is next to godliness... but in my case would I still have to remove all the AVCR hardware - both in-car and under-bonnet?
I received a 'noise' one today - and am expecting an 'emissions' one very soon.
Noise was TMU on Chapel on my way home from Coles - didn't stop me but I guess they don't have to. The other was a defect inspection at a booze bus. Cop said as I have the AVCR he has to send me to the EPA... so I guess it is just the standard Macleod one.
Pretty annoyed about the whole thing - been a bad week.
oh a simple one....just take the sh1t off and put it back on after.....a mate of mine got done the full hog(Big turbo,external waste gate,custom plenum ect) and when he got there they had laminated pics of the engine bay from when he got done...he fitted a standard motor the guy just came over pulled the hood then closed it then walked away...its not a major check out...should be easy for you...
Hey james.. so you get the magic letter too ;) It can take a month or so to arrive.
Yeah, its nothing to stress about.. The EPA guy I dealt with was pretty cool, and I've never really heard any horror stories about the checking, but the EPA guy will read what the cop has put on it. If the cop is being a bitch you might have to watch.,
With the boost, yeah, better to set it back to stock. They WILL definitely check for a stock boost solenoid, they know how to look for that. Same for an aftermarket BOV. They'll stick a torch under the car to make sure you have the required cat too.
EPA guy looked at my big old HKS FMIC and said "one intake is fine, either one of pod or intercooler and you can pass". I'd put the stock airbox on.. its a 20min job.
They basically test you for emissions with a doova up the back zorst and the CO levels at 0.xx% (or whatever the figure is), so anything that plays with the level probably isn't a good idea. I'm sure there is enough leeway for you to pass with a boost controller and PFC but its best not to risk it.
I reckon you'd wanna be careful with stuffed o^2 sensors, but only one real way to find out! If you don't pass the test then you've got xx days to get it fixed and come back again for a free re-sit (woohoo!)
With noise, what I was told was that its exactly ON or under, then you're fine. I think mine was 89db and the limit is 90db so that was fine. If its a "factory" 95db you probably want to get it checked before, as you never know what conditions and what GTR they tested it on.
You might not actually have to remove the AVC-R but anyhow, i'll PM you on that. I just disconnected the controller box from inside the cabin and the control in the engine bay.. left the piping in place to save me dicking with that feeding it back (ag). There's nothing against having an empty hose or two in the engine bay anyhow. The ECU they'll pop the kick panel so better get a stock GTR one.
I had my car back to "normal" the same night, so its no problemo.
Thanks Gordo.
Jack is helping me out with the computer, and well... I probably should get a cat ;)
Will wait and see when letter comes if I can knock the two over together.
Will PM you nearer the time...
Hope QLD is as good as it looks and more. I've had enough Vic... might head north also :D
Thanks Gordo.
James
I've got a stock air box & stock ecu if you need a lend of it. You'll Just need to source the filter for the box.
Are you serious the PFC is not allowed?? if so why?
ppl,
Just wondering why you have to remove the powerfc as both times i got pulled over they were looking for/asking for any other computers..etc...
also Jamezilla when do you have to go to macloed...? dont tell me its the 18th of feb...?
so far me and another sau cruiser are booked in for same day....
a few more and we could have a cruise to the epa... :headspin:
If your worried about emissions/o2 sensor, you can go to most mechanics and get that sniffer up your exhaust (after the cat install ofcourse) to have a look and see if it complies
I belive you have to be running pretty rich for it to not pass...
I know an FD RX7 that passed emissions without a cat :freak:
Seriously people, dont you think enough is enough?? Each department reminds me of the World Idol judges, everyones trying to out-do each other with their ego's. One says this, the other says that... bla bla. Once & for all, is there a way where we could perhaps confirm what is & what isn't acceptable.
Like VO5 - "it wont happen straight away, but it will happen" when you get that letter! :)
James i wouldnt stress even 1% about the EPA test. The EPA testers know cops r full of shit 90% of the time with these epa tests and that it wastes your time and their time.
:werd:
meshmesh - that is the problem, there is no definitive what IS legal everywhere, fully, every step across cops, EPA, vicroads, ADRs and god knows what other legislations are out there. The whole system needs to be overhauled from the ground up, as it stands now, its pretty illegitimate. But then again maybe the current scheme is not so bad...it could be worse trust me..
do they check engine numbers etc?
maybe u could do a secret squirrel and get someone with a stock R33 GTR thats purple and swap the number plates and rego sticker :)
I think they tried 2 on my test, and he asked me where the engine number was so i said down near the turbo, but i dont think he could see it properly coz it aint stamped that clear in the first place.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
