Item: 1994 Nissan S14/200sx with evil eye conversion, 207000km on the chassis, 25000km on forged motor, 5 speed manual, rego until March 2011
Specs as follows:
Engine/Electronics:
Fully forged SR20 bottom end (has 25000km on it since install - CP pistons with 86.5 bore, Eagle rods, ARP headstuds, ARP mainstuds, crankshaft machined and balanced)
HKS metal head gasket 1.2mm
Trust rocker arm stopper
brand new oil pump
brand new water pump
brand new timing chain and tensioner
diff and gearbox fluids changed 10000km ago
high flowed T28 turbo (tuned at 19psi)
HKS SSQ BOV
550cc injectors
Apexi AVC-r electronic boost controller
Apexi power fc j-detro with hand controller and air flow meter removed
direct intake pipe from K&N pod filter to the turbo
Coolingpro aluminium radiator
Hi Octane radiator air guide
Apexi 1.3kpa radiator cap
heavy duty racing grade blue radiator hoses
Hybrid front mount intercooler
Hybrid vacuum distributor
blue racing grade vacuum hosing (with spare length)
Apexi aluminium induction box for pod filter
Walbro 500hp fuel pump
mandrel bend 3 inch exhaust system from the turbo back with sports cat converter and 4 inch X-Force cannon (with silencer aswell if required)
Tien Super Street suspension
adjustable caster bushes
full adjustable camber kit
all front bushes replaced with new urethane bushes
Cusco front and rear strut braces
(have dyno sheet for 215.9rwkw)
Interior:
Sparco X-Fast gear knob
Sparco steering wheel
leather “Silvia” embossed gear boot
2 x Monxa SP12 reclinable sports seats
“Silvia” embossed vinal rear seat cover (black and light blue)
colour coded dash (same colour as exterior - centre console lid, ignition barrel surround, dash cluster surround, gearbox lid, stereo surround, air conditioner surround)
Exterior:
Genuine Uras S14 Type S full kit (front bar, rear bar side skirts) - imported myself from Japan
Uras 25mm wide vented front guards
full respray in Opal (blue base layer with purple and green pearl)
Lenso D1r 5 spoke rims - black painted centre with polished lip (275/17/40 rear and 245/17/40 front – 98% Sumitomo rubber)
5Zigen lock nuts made of aircraft alloy
S15 “lightening bolt” badge on bonnet
personalized number plates (black with metallic silver writing)
smoked tail lights with garnish, smoked front bar blinker, smoked front corner blinker (have original tail lights and garnish aswell if required)
shaved ariel hole and spoiler holes
30% tinted windows
Stereo:
JVC KW-AVX810 double din dvd player (dvd-r, dvd+r, cd-r, mp3, avi, divx, usb input, SD memory card reader, optional input for reversing camera, has bluetooth with module for most motorola phones)
pair of alpine 6½ inch 3 way splits with cross overs (front doors)
pair of alpine 6½ inch 2 ways (rear parcel shelf)
pair of Clarion 10 inch subwoofers
Clarion V-Net 450 amp
have receipts for almost everything since I purchased the car in 2007
Reason for Selling: I'm currently overseas so instead of having it sit there I'd like to see someone else enjoy it
Contact Details: The vehicle is with my parents so there are a few options...my mother's mobile number is 0412696751 or you can email me at [email protected] or simply PM me through here and I'll get back to you...
Price: $13 999 ono (No Swaps)
Recent Pictures:
Hello Friendly Skyline Driver,
I was looking at your car and am quite intrested, it just seems a daunting that there is evil eyes in this car as you said. Why did you put them in? And what makes them evil? Are you sure theyre not regular eyes?
Thankyou.
vertex kits are common...i wanted something out of the ordinary...and i will find the right person to take this off my hands
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
    • Most of the R33 GTST S1 are all like "airbag? What airbag?!"
