hey all, im new to this site & skylines
i recently bought a R33 GTS4 paid about 3500 for it.
i was just wondering is there a way to disable the attesa system?
and then simply just plug it in again?
or is this only the R32's?
any feedback would be greatly appreciated:)
thanks
https://www.sau.com.au/forums/topic/329610-gts-4/
you cannot just pull out a fuse like in the 32's. this is because their system was electrical and the 33's are hydrological.
You can drain the resovior in the boot but the safest thing to do is take out the front drive shaft.
BTW, how did you manage a 33 gts4 for 3.5k? is it damaged?
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5356095
The caniser in the boot runs down to the actuator on the O\S\R of the car, it pumps fluids to the transfer case and when the slip light is activated it then runs too the rear diff and is pumped around there aswell, then back too the canister. It does this because it is a high pressured pump that activates clutch packs in the transfer case, this is how the attesa system works. Do not take the fluid out of the clutch packs with be distroid and you will have to spend a lot of money and all the parts with be EX jap.
The fluid is a ATF fluid, at nissan we sell nissan Matic D which is what they used stock.
You can take the front propeller shaft out but thats it.
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5357381
how would i pull out the shafts? just pull them out
your only taking out the front shaft.
It is located under the car more towards the drivers side next to the gear box area.
there are four bolts that attach it to the car, they are in pricks of a position to get off...
the thing i do is, move one bolt at a time to the best position possible for you to reach by rolling the car, undo it and take it off, roll your car a little back or forward so the next bolt is in the same position and repeat.
when you get good at it, you can have it off in 10-15 mins if that....
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5357421
As said before.
You can only disconnect the 4wd system in the R32's electronically.
In the 33 and 34 you must remove the front drive shaft.
This is the shaft from your transferbox (the thing hanging off the drivers side of the gearbox) going up to the front diff.
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5359314
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
    • Awesome! I was thinking S14 since they are longer. I'll give those a shot. Thanks for the input!
