hey all, im new to this site & skylines
i recently bought a R33 GTS4 paid about 3500 for it.
i was just wondering is there a way to disable the attesa system?
and then simply just plug it in again?
or is this only the R32's?
any feedback would be greatly appreciated:)
thanks
https://www.sau.com.au/forums/topic/329610-gts-4/
you cannot just pull out a fuse like in the 32's. this is because their system was electrical and the 33's are hydrological.
You can drain the resovior in the boot but the safest thing to do is take out the front drive shaft.
BTW, how did you manage a 33 gts4 for 3.5k? is it damaged?
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5356095
The caniser in the boot runs down to the actuator on the O\S\R of the car, it pumps fluids to the transfer case and when the slip light is activated it then runs too the rear diff and is pumped around there aswell, then back too the canister. It does this because it is a high pressured pump that activates clutch packs in the transfer case, this is how the attesa system works. Do not take the fluid out of the clutch packs with be distroid and you will have to spend a lot of money and all the parts with be EX jap.
The fluid is a ATF fluid, at nissan we sell nissan Matic D which is what they used stock.
You can take the front propeller shaft out but thats it.
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5357381
how would i pull out the shafts? just pull them out
your only taking out the front shaft.
It is located under the car more towards the drivers side next to the gear box area.
there are four bolts that attach it to the car, they are in pricks of a position to get off...
the thing i do is, move one bolt at a time to the best position possible for you to reach by rolling the car, undo it and take it off, roll your car a little back or forward so the next bolt is in the same position and repeat.
when you get good at it, you can have it off in 10-15 mins if that....
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5357421
As said before.
You can only disconnect the 4wd system in the R32's electronically.
In the 33 and 34 you must remove the front drive shaft.
This is the shaft from your transferbox (the thing hanging off the drivers side of the gearbox) going up to the front diff.
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5359314
    • Hahaha wow that was dead on! 🤣
    • Somehow we've reenacted this video completely seriously:
    • Nistune is pretty easy if all you want to do is change the injectors. TIM + latency change will do it. But I am very skeptical your mechanic has actually diagnosed the issue. As others have said flow/function test your injectors.
    • ^This. If you have to do injectors, and you have to buy bigger ones, get the smallest Bosch EV14 based injectors of the correct length that you can. This will be about 500-525cc most likely. The stock ECU (with Nistune) will be fine to run those. Then, use a Nistune. Tune it yourself. If all that you are doing is changing injector size, then you literally only have to change one number to do it, and then maybe some fine tuning of that number. You will not need to touch the fuel or ignition maps at all.
    • I don't know what those pipes are, but I'd say there is a good chance they are old school Japanese tuner because they are equal length and nicely made. Maybe someone like @Rezz who has direct access to japanese history might be able to help. Even so, I'm not sure what inspectors could check it to, they presumably are googling 30 year old japanese stuff same as us.
